NorthernMuscle
I'm pretty happy with my current setup relative to what it cost me, but interested in your thoughts on what I should consider doing to do next, if I wanted to turn up the fun factor?
This 2015 GTPP is my third Mustang, but first S550. Stock power was as expected, but was very disappointed with the handling... so I focused on that a year or so ago. My current upgrades are listed below, which mostly focus on making it a better handling street car.
Although the supercharger on my previous 08 Roush Stage3 was the most fun part of that car, and although a few hundred HP would definitely turn up the fun factor on this car, I'm a bit hesitant to go down the path of adding a SC... partly due to the cost, but mostly due to the slippery slope of associated upgrades which start getting recommended (drive/half shafts, etc, etc.) that I'd get sucked into buying. I like balance, so I'm not that guy who would be happy with 800hp in a stock GT.
It's also more my style to hold off on something like big power upgrades for a 5yr old daily driver with 50,000kms, and just get a GT350 or something similar in a few years, with that extra power already "built in".
The weakest points of my setup (for my preferences) would be:
- suspension travel (although I'm not looking to replace the shocks/struts I already put on). The handling when within travel is great. The setup and alignment is far better than most. I only wish I'd gone with options that gave more overall travel.
- power (although I'm not that keen on going down that slippery slope with 5yr old daily driver)
I've had this car for 1.5yrs, and plan to replace it in 1-3yrs. That "something" will either be a newer GT that I mod the heck out of, or something along the lines of a GT350, that's more purpose built for higher fun factor, but still has upgrade potential. Personally I find it to be a difficult balance, since there are parts of a GT350/500 that I'm pretty sure I'd still want to upgrade, but on the other end of the spectrum, if you buy a stock GT, there's too much to replace, and in the middle, someone like me buying a GT PP ends up paying extra for all kinds of parts that still suck relative to aftermarket options.
Any feedback is much appreciated
(even if it's to just sit tight, or to get a SC, or to get a different car lol)
Thanks!
BMR:
SP083 Springs (Love them after trying their softer springs, and Eibach's common lowering springs)
Front/Rear Sway Bars & End Links
K-Brace
Vertical Links
Rear Toe Links
IRS Cradle Bushing Lockout (must have upgrade)
Jacking Rails
Steeda:
Adjustable Pro-Action Shocks/Struts
Rear Shock Mounts
Bump Steer Kit
IRS Cradle Alignment Inserts
Clutch Return Spring (must have upgrade)
Roush:
Axle-Backs
Cold Air Intake
ECU Flash
Other:
Mishimoto H-Pipe
Maximum Motorsports Caster Camber Plates
RTR Tech7 20" staggered wheels (love these for their weight saving over 19" PP wheels, and for their $$ value)
F=275/ R=295 /35/20 Pilot Super Sports
Barton Hybrid-3 shifter (LOVE the fun factor this added!)
Whiteline Transmission Bushing Insert
FP Knuckle To Toe Link Bearing
Aggressive street/mild(ish) track alignment
For those that don't know, this PP came from factory with Brembo brakes, and 3.73 rear
Thanks!
BMR:
K-Brace
Vertical Links
Rear Toe Links
Jacking Rails
Steeda:
Rear Shock Mounts
Bump Steer Kit
Roush:
Axle-Backs
Cold Air Intake
ECU Flash
Other:
Mishimoto H-Pipe
