Let's talk crank damper/balancers, IW vs ATI vs Stock
john@fatfab
Indianapolis
Shelby Omni
Fathouse just does basically the same parts as Hellion on their 800r package. It is manifolds, piping, intercoolers, injectors, turbos, bovs, wastegates, oil feed/return.. Not even a fuel pump booster.
None of our turbo packages are based off of stock manifolds. There is a lot of differences between these kits when you look closely and start comparing them.
mmakam2
Houston, TX
2019 GT350
Hellion has a upgrade 4to1 manifold upgrade, Aldo Welds also does in its base kit.
I'dllove to see more about the difference between the kits but I understand if that's proprietary.
mmakam2
Houston, TX
2019 GT350
Hey guys I just finished the install with the IW damper.
Noticeably less NVH in the cabin, I also did a 3500rpm vibration test through the shifter and it's obviously reduced the amount of vibration through the shifter.
I also noticed a rattle in the exhaust is gone that used to be there in sport mode.
On top of all this it feels like it pulls a bit harder and Rev matches quicker from the weight savings but this may be placebo.
All in all good mod, and for me a good option to not do OPGs for maybe 5-10k miles if I'm careful about not bouncing off the limiter etc..
