Lethal Performance Double H pipe 2020
FrankM5
California
Frank
2019 Mustang GT 401a package
I wanted to add this double hpipe everything else exhaust wise is stock will the h pipe make my car loud or hardly louder? i never installed any type of exhaust yet and i do see other h pipes for 300 while this one is high 5s so let me know if this is also worth the money thanks alot
NeedForGreen
2019 Mustang GT
It will make it a tad louder than a single h pipe, but will also change the tone more. Just depends on what sound you're after.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Double H-pipe? WTH is the point of that?
Interceptor
Daily Driver
Low country South Carolina
2019 California Special A10
As hot exhaust gases acellular to find an exit suitable, the hot gases become confused. In an elementary description the exhaust gases are male female, and undecided.
As the male hot gases reach the intersection of first "H" they cross over.
The female gases that are attached to males gases follow their males gases at first "H". The unattached female gases will either follow the original flow pattern or move over at next "H" connection, if they miss some of their male or female gases that passed over at first "H". Also at this time some male or female gases may switch over at 2nd "H" just because their gases are getting to crowded or hot.
The undecided gases have no pattern, some stop and protest, some try to reverse direction, this is where all the low grumbling comes from. If you run a straight dual pipe with no cross overs then their is no confusing so there isn't a lot of grumbling. Male gases on oneside, female gases on the other. When you start mixing all the gases up is when you have the issue of gasses fighting and yelling at each other.
FruityJudy
South Alabama
2018 Mustang GT A10
So you have male and female and an h pipe kinda makes things gender neutral right?
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Huh? All and H-pipe does
Every H is 2.5 horsepower. Everyone knows that
My single H added 6. Sooooo double H you lose 1 hp. Sweet.
Stephen@lethal
2020 Mustang Gt500
The double H is just a name they gave for it, like the double helix pipe that is similar. Its built that way for resonance to tone it down since Coyotes are very raspy with exhausts.
