Left rear grinding noise
Shibaman
Elk Grove ca
2019 Bullitt. BAD GRN
When i turn to the right on a corner i can hear what sounds like a grinding......some times clunking. A long on or off ramp is quite loud. Going straight at low speeds, if i crank the wheel to the right putting pressure on the left side, i get noise. When i back down the driveway the wheel is turned full right. The rear left wheel makes a grinding sound. Seems like there is resistance also. Checked the torque on the lug nuts. Correct.
Any ideas?
My 19 Bullitt only has 9000 mi on it. Not abused, but driven to have fun.
o-man
Durham, NC
Oscar
2019 Ford Mustang Bullitt
Possible wheel bearing? I had two replaced under warranty
daSNAK3
Cary, IL
Jake
2021 GT
Have you checked the Wheel Hubs?
Shibaman
Shibaman
Elk Grove ca
I have not checked the hubs. This just happened recently.
O-man. 2 wheel berrings? Damn!
Going to talk to the local dealer tomorrow. Thanks
Shibaman
Shibaman
Elk Grove ca
It turns out my hearing is not all that great. It was the right front oem rim rubbing on the front strut.
Out local Americas tires screwed up.
On the right side they mounted the 9.5 inch rim up front....the 9 inch in the back. The strut is ok, but the rim has damage from grinding against the strut.
Americas wants to see if it can be refinnished. Repaired. I think they owe me a new rim. Also pay the bill from the ford dealer for the diagnosis.
What do you think ? What should it i do?
Thanks
Ballistica
Chicago
Scott
2021 Mustang GT Premium
Thanks
Wow, thats quite a mistake. I'd say they owe you a new rim for sure. Thats not a mistake on your part.
Shibaman
Shibaman
Elk Grove ca
Supposedly Americas tires is going to pay my $195.00 bill from ford. They said the are going to replace the damaged right rear with a new one. Back ordered to the end of july. We will see.
Meanwhile i am looking for anther set for spairs
