Launch Control
SNARLINGCoyote5.0
2015 GT Performance package
How do you put in track mode don't you need a premium ? I don't have a premium just base with performance pack .
dubster99
Nor*Cal
2015 Ingot Silver GT PP
Hold the middle button that looks like a steering wheel until you see "advancetrac off" on the display between the gauges.
phunk
United States
'15 GT-PP
LC works in all modes.
LC automatically turns off if you turn off traction control, unless you are in track mode, it will LC with traction off.
If you dont see "LC" at the bottom right corner of the LCD display, its not going to hold the RPM.
anotherneon
15' base GT w/3.55s
Yes this. Just set it and go, you dont have to change modes lol.
v8ter
Typing...
EL PASO , TX
MUSTANG GT 2015 50TH
If you turn traction control off, RPM shows instead of LC ,and it keeps holding Rpm
phunk
United States
'15 GT-PP
Negative. It does say "RPM", but it will not activate launch control. This is also why when you turn off traction control in any mode other than track, you immediately get a notification that says "launch control not available".
v8ter
Typing...
EL PASO , TX
I didnt say that launch control was active then,what Im saying is that Rpm keeps holding to the setting on the launch control menu
phunk
United States
'15 GT-PP
RPM holding to the setting on the launch control menu = launch control active... which it is not when you turn off traction control and it only says RPM instead of LC and gives you a message saying "launch control not available".
