Gruntus
My experiences
Hi All, thought I'd share my personal experiences installing the DRL/Fog/Parking LED package.
- Fog lamps: really simple, easy to access, remove and replace as shown by Kaps
- DRLs: not so easy to access, passenger side replaced OK after about 10 minutes of mucking around trying to align but pushed in and locked into place. Drivers side had a real issue with, could not get locked into place even though it was aligned. Tried a number of times and spent well over 3 hours but best I could get was it sort of being wedged into the socket. Seems to have worked as has not displaced after 1000+ Kms. Reckon issue is a combination of location, bulb not being exactly right (was able to put back old bulb with ease), and strength in left arm
- Parking light/Front side lamp: Earlier poster mentioned to follow the owner's manual and all is OK. Did this and could not get bulb out. Tried needle nosed pliers but too bid for space. Bought some small pliers to get to bulb and managed to only break the socket by pulling out one of the contacts. What I have now worked out is that the manual IS WRONG, don't follow it. Point 5 of the Front Side Lamp replacement on page 157 says to "Remove the bulb by pulling it straight out.", DON'T. As per the other bulbs you need to twist counter clockwise by an 1/8th of a turn and then pull out. Once I worked this out then it was easy to get out and replace.....just waiting on a new socket ($7) to be shipped up from Melbourne
Good luck
Good luck
