mbreinin
- Nov 18, 2014
- New Orleans, Booziana.
- mike
- 2015 EcoBoost Premium.
Yeah, tomorrow.1 week old? bring it back to the dealer.
Update: did some runs tonight in the interstate. 4th/5th gear.
3/4 throttle: 17.7lbs and it spikes on occasion to 14.4 af/r then it reigns it back in to about 13.9. When this happens I get a harsh ping/knock. From my previous knowledge this af/r should be closer to 12 on full boost. Why it's targeting 13.9 at part throttle is beyond me.
WOT throttle: 16/17lbs and 11.6 af/r. Health happy.
Put a half tank of 93 in when it was almost empty. Not solving the issue.
Thoughts?
I tried checking the clamps on the piping, can't reach the two intercooler clamps atm
so what you're saying is Ford fucked up?The reason you are getting knock when you are doing 3/4 throttle is because you aren't past the threshold for power demand fueling. You are on the brink of it so it's going to command as close to stoich as it can.
When you get on the throttle 100%, everything is fine and that is because it is in power demand fueling.
This can be changed in a tune, but if you are driving on the factory setup it is going to ping/knock at 3/4 throttle if you are making that much boost and revving it high. I honestly don't know why you would ever need to do a 3/4 pull. If you are passing someone just get in it 40-50%, if you want to go fast floor it!
No, what I'm saying is your driving habits are odd and doing a half tank of 87 with a half tank of 93 isn't going to get the premium fuel that Ford recommends.so what you're saying is Ford fucked up?
and they should have used a MAF instead?
its pinging all over the place. ill drop by the dealer and driver another one and see if the numbers are the same as mine.
btw should i even bother resetting the ECU (if thats even possible)?
there was .5 gallon of 87 in and i added 8.5 of 93 premium. so i did my due diligence.No, what I'm saying is your driving habits are odd and doing a half tank of 87 with a half tank of 93 isn't going to get the premium fuel that Ford recommends.
That is still only 90 octane when mixed like that. I highly recommend doing two things. Getting a full tank of 93 in the car, and picking up a set of plugs to ditch the factory spark plugs.
http://goo.gl/gKzce4
Click there for some plugs already setup for your car.
thanks Mike.For the record, mine never pinged at any throttle level with a factory tune. It has had two tanks of 87 in it in a year....dealer fill and once I accidentally filled it with 87.
Thanks. I'd take it today but I'm out of town for work for 7 days starting tonight.My car has been having a similar issue in the past few weeks, but I have a tune and intake. My car never did this when stock. I'm amazed that you're having troubles this soon. I had 87 in mine from the dealer when I first got it too but it still ran fine. In the owners manuals it says you can run 87, you just lose 30-40 hp. Even on 87 the car should just give you less power and maintain it's smoothness. If I were you I'd go straight to the dealer and if they can't fix it the first time around I'd see if there is any way to get a different one.
This is the first time I've heard/seen of this. You've spoken several times about maintaining the warranty, so with that said, use that warranty and take it to the dealership. Tell them you're hearing the pinging and what you're noticing with the AFR and ask them to reflash the ECU. Also, if you have access to somewhere that sells unleaded race gas (search Google around your area), then throw 3-4 gallons of 100 octane in it and see if that causes it to stop.
I just thought of this too. Mine makes a knocking/pinging noise too, but it's the DI system. It almost sounds like a knocking sound, especially under light throttle. Under heavy throttle, the engine makes enough noise to drown it out. I'd almost bet cash that that's what you're hearing.
Sent from my XT1095 using Tapatalk
Sunoco's website will show if they have 100 octane near you, I'm paying $8.99 a gallon for it in south FL.Also, if you have access to somewhere that sells unleaded race gas (search Google around your area), then throw 3-4 gallons of 100 octane in it and see if that causes it to stop.
