JMS BAP install question
z06psi
Evans, GA.
Andrew
The pot stirrer
So I installed the JMS BAP. Everything is good but there are two ground wires that accompany the pedal connection. They are both heat shrinked over. Do they need to be hooked up to a ground? No mention of them in the instructions. Thanks in advance.
z06psi
z06psi
Evans, GA.
Andrew
The pot stirrer
Beefcake said the same. I wonder if it is for the control knob.
Sent from my SM-N910V using Tapatalk
beefcake
Bethel
2018 Ford Mustang
For a hobbs switch
D3adch1ld
Blabber Mouth
New York
Marcos
15 Mustang GT Premum w/ Performance Pack
Ahhhhh. 5v trigger.
Hey, Curious how you set your dip switches. Mind telling me.. I'm using 1-2 off, 3 on, 4 off, 5 on. Currently running the pedal switch, no hobbs switch.
Thanks in advance.
z06psi
z06psi
Evans, GA.
Andrew
The pot stirrer
lsxlol
NC
2015 white gt On3 TT // ID1000s // BAP // Corsa Xt
I accidentally ordered the wrong JMS BAP I got one for a 2011-2014 car and I have a 2015 Besides the plug been different if I hardwire it will it function the same ??
zaquhree
Orlando
2015 S550 GT
I heatshrinked mine and ziptied them out of the way for cleanliness
rredd14
Mississippi
Robert
Magnetic 2018 GT A10
What location in the fuse box under the hood did yall install the 30amp fuse supplied with the kit?
z06psi
z06psi
Evans, GA.
Andrew
The pot stirrer
15s and 16s come with a 30 amp fuse. At least mine did.
arieso94z28
New Mexico
I did not have to upgrade the fuse in my 15' either. Already had a 30 amp fuse.
