JMS BAP Install Question
Jalis
Earth
2014 GT
About to finish up the wiring for the BAP - only question I had that I didnt see in the instructions, are the (2) ground wires on the control harness needed (Its grounded in the trunk on the unit directly), or just plug in the TPS plug-n-play adaptor and call it a day?
MyLilPony
Naw It's Stock
Prosper, TX
Kris
2015 Black GT, 18 JLUR, 15 JK
If it is the Plug and Play version there is only one ground wire from what I remember; the one you have grounded already. The others are for a hobs switch.
r1lovin
colorado
2015 Gt
Just ground the box. The others are not needed
MyYellowPony
Chicago
Trip Yel GT Prem PP
i installed an f1a on my GT and id1300s and ngk plugs and jus bap. once all was installed the car cranks but won't fire up. any ideas? car fired after PC install. car fired after spark plugs and injectors. then once bap was installed it would not fire. *car has not been tuned yet. just started and checked for any leaks of any sort. seems that the problem came after bap install. any ideas?
r1lovin
colorado
2015 Gt
Is it the plug and play? Check that the plugs are tight and check your fuse
MyLilPony
Naw It's Stock
Prosper, TX
Kris
Weird, bap isn't active during start up. Grounding issue on the bap maybe! Since it intercept signal maybe that is causing and issue. Have you adjusted the settings on the BAP already?
MyYellowPony
Chicago
Trip Yel GT Prem PP
gonna check the ground tomorrow first thing. haven't altered settings. once it was plugged in i just wanted to see if it would fire up. thanks for the reply! much appreciated. also just followed you on ig:headbang:
