JLT Intake everything wrong
Stephent5609
Stephen
Mustang GT
Alright guys I’m beyond annoyed. I know they say things never go as planned but this simple JLT CAI is kicking my butt.
If I leave my car alone for a day or so and start it the car shuts down always first time. And then is fine afterwards.
I was told because I need the tune is why this happens as well as the check engine light. And now I’m trying to do a tune with Lund racing and I did I crank relearn and all these codes popped. I’m so done with this car
Syphon5.0
NY
Adam
2015 GT 50th Anniversary
Its probably something you did and not the intake. Took me 15 mins to install my JLT and Lund Tune.
Stephent5609
Stephen
Mustang GT
I haven’t done the tune yet, just the diagnostic so Lund can get an idea from there. I told them the check engine light was on so they said do a check engine light so they have an idea of what it is exactly.
Syphon5.0
NY
Adam
You shouldnt have even put it on till you had the tune. When you buy the NGauge from Lund they ask whats done to the car. So they can send you a tune for those mods. For instance I told them I was putting on a JLT intake and MRPB catback race exhaust. So they pulled a base file for those mods and sent it to me. I installed the mods on the car and tune the same day. Everything went smooth. I data logged for them, sent file to them. Everything looked good and didnt need a re-tune.
cahouston
Houston
2019 Mustang GT A10 Premium
At this point with your car throwing codes after running with a tune-required mod (JLT CAI) on the stock tune, I wish be hesitant to give you a tune if I were a tuner as well given your car is throwing codes. Your best bet is to disconnect the battery, put the stock parts back on, reconnect battery, start it up, and check for codes from there to make sure the car is healthy. Then, work with Lund to get a tune for the CAI. Once you have the tune, install JLT, load tune, and enjoy. Hopefully, nothing was damaged by running the car with a tune-required CAI on stock tune.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Weeeellllll you need a tune BEFORE you run it, period, end of story. And why you making lund chase it? When they ask if you have a tune required CAI, you say yes, boom here's your tune.
Shifting_Gears
South Florida
Your MAF readings will be completely out of whack which is why the car won’t run. There’s “tune required” intakes, such as the JLT, and “no tune” intakes such as K&N, AEM, etc.. or some that offer both (Steeda, Roush) with a removable insert.
You’re best off to re-install the stock intake until you purchase the tune.. otherwise you’ll have the same issue.
Not to be a dick, but it’s not the car’s fault :)
Stephent5609
Stephen
Mustang GT
Did base tune and god came clutch, no CEL.
Kermitz
Vacaville CA
Seth
2019 Mustang GT PP1 300A M6
Didn't you just post about this on 05-11-2020? You were advised to put the stock intake back on and not reinstall it until you have a tune for the JLT intake. Did you do that?
Stephent5609
Stephen
Mustang GT
No I just had the Lund tune do a baseline tune for the CAI. There was no hesitance doing cold start, no codes popped. All in all I didn’t run the CAI
(before tune) to the ground. Data logged and sent it to Lund racing from there, dependent on the numbers, I should get my selected flex fuel tune.
CommyO
Is it a v8?
Venus
15 EB Premium PP
I installed my intake without a tune and it was fine. I did tune the car of course but it shouldn't be turning off
ivantwilliams
Georgia, USA
2018 Mustang GT Premium with Performance Package
I am intrigued by MODs. Alas, not doing any till my warranty runs out. But, confused why a CAI needs a 'tune'. I will research and watch a few YouTube videos.
Oddly, you'd think since it is air passing through the CAI, one would not need a tune.
geddys
Europe, Poland
Mustang 2016 GT, Europe edition
On intake you have a MAF ( mass air-flow sensor ) which measures how much air is going inside the engine. ECU uses this reading to calculate how much fuel needs to be injected to reach proper AFR (air-to-fuel ratio) during combustion.
Some intakes increase tube diameter which makes more air to enter engine, while MAF reads same numbers as before, making ECU inject not enough fuel for proper combustion. ECU has in-built mechanisms for correcting this, but its so much out of scale for ECU that it doesnt work. Tune just makes adjustments for this. ( Thats really high level view on the case, some details might not be correct in this scenario )
Rock&Roll
New York
2016 GT Stick- 2022 VW GTI Stick -2011 HD Fatboy
I am intrigued by MODs. Alas, not doing any till my warranty runs out. .
Lol ... I’m not screwing my car up either. There’s no improvement from installing aftermarket CAI. The stock one works fine. A tune will benefit but I just don’t want to mess with a car that already hauls ass but I get why people do it ... just not for me :)
