Is WELD 18x10.... square fitup possible
DAVECS1
Peoria IL
2017 PP GT Grabber Blue
So I have been shopping for some wheels that will look good and hold up to the playtime my car sees. I do quite a bit of road course stuff. I know Welds are not usually considered for cars working tracks with corners, but I am partial to the look and they seem to have the right build quality for the job. Would it be possible to run the 18x10 or wider variants in a square set up for hpde work? I notice those sizes are running a 56mm backspace and the forgeline and apex 18 square setups are at 52mm. I have a 2017 GT PP so I imagine brakes may be an issue. Any help qould be appreciated.
EFI
Masshole central
5.Br0
It's going to be questionable whether they fit over the Brembo brakes, but if you get the right offset then they should fit as any other wheel of that size. Curious also to see if anyone has tested these over the front brakes.
DAVECS1
DAVECS1
Peoria IL
Thought about calling Lethal and having them give it a try as they seem to run a few sets.
