Is this true about vodoo engine?
MCarsFan
East
2017 GT350
I read somewhere that if you stay around 8000 rpm 8 seconds, redline goes below 6250 for 15 seconds or until you go below 5000 rpm. I hope I read this wrong and its not as bad as it sounds....
Rogue
Porsche 911 Carrera S, Boss 302 Laguna Seca, Jagua
I read somewhere that if you stay around 8000 rpm 8 seconds, redline goes below 6250 for 15 seconds or until you go below 5000 rpm. This sounds like that 1-4 gear bs GM has for corvette but much worse. I dont see Porsche limiting how long you can stay at 9000 rpm. I hope I read this wrong and its not as bad as it sounds....
That was a false rumor.
Myshelby3425
Miami
2018 GT
Why would someone hold an rpm that high? Unless your at the top of 6 gear (overdrive) holding that rpm, you wouldn't be in that range of rpm more than 1-2 seconds.
Bossing
attacks tracks
So. FL
Just can't get enuff!
Yeah IIRC that was inadvertently copied & pasted from the GT500 owner's manual....
FPCV8YO
Rode Hard & Put Away Wet
South OC
2006 350Z GT Roadster
It was more than a rumor as it was in an official document from Ford which I believe was for their sales people however, as stated, it wasn't true thankfully.
84venom
2000 Cobra R, 2016 GT350 TP DIB w/White Stripes
I can't understand why someone would do that anyway? Even on the banks at Daytona road course you're only at high RPM for a few seconds.... Maybe if you were running the full oval? So again, why???
Epiphany
Global
I like to disassemble things.
Because racecar?
GT_Dave
NE Illinois
1970 Mach 1 408EFI , 2016 GT350
Not to be picky on the technicals, the car is not capable of going to 8,000 RPM in 6th gear. Top speed of 170 MPH for this car in stock trim is achieved in 5th gear. Not enough HP to pull 6th gear to the top in a real world run, you could do it on a dyno with no wind resistance.
Myshelby3425
Miami
2018 GT
The car is not capable of going to 8,000 RPM in 6th gear, top speed of 170 MPH for this car in stock trim is achieved in 5th. Not enough HP to pull 6th gear to the top in a real world run, you could do it on a dyno with no wind resistance.
Then this car will never be in the 8000 range longer than 2-3 seconds max topping out 5th.. Don't understand peoples concern.
