Intermittent Sputtering, IDEAS!
Nomad
In the garage
2015 GT
Saying "your car is messed up" isn't a viable diagnosis. Having an issue like this means something is wrong, no doubt. If the Procharger wasn't on there would this problem still be there? Probably not.
I'd start by going over everything related to having a vacuum leak.
Phils15GT
Albany, NY
I forgot to hit the start button at the track yesterday. It would have been a good run to log as the car was running like pud. I tried to datalog the car on the way home, 3 times, but it was running fine on all 3 pulls.
Guess I will have to take the car out and log it until it does it again.
Seemed to do it much worse at the track than ever before.
redline727
Thread Killer
Mooresville NC
Rocky
2021 Oxford White Mustang GT
I wonder if it's a heat issue then since it seems to happen most during track conditions.
Again not too familiar with properties of E85 or the Fore fuel system. But is it possible the fuel is getting too hot? Did you have to run any lines that may be too close to a heat source? I know that when fuel gets really hot it can cause all sorts of mixture issues. Because it's essentially starting to vaporize before it hits the cylinder.
Nomad
In the garage
2015 GT
Doubt this. I have a Fore stage 2 system on E85 with no issues to speak of.
I make it a habit to NEVER make wot pulls without data logging it. Matter of fact I always have my X4 plugged in and ready to log. That way I can see what it's doing. Now if I'm just quickly nailing the throttle I won't, but if I'm pulling it to 4th gear, I'm logging it. It also helps so you can just hit the button and capture the data.
Phils15GT
Albany, NY
I'm going to try and get a few more logs before the real cold hits.
beefcake
Bethel
2018 Ford Mustang
what are your plugs gapped at and what boost are you seeing, first thing to try would be tightening the gap up.
Phils15GT
Albany, NY
I had brisk plugs gapped at 25, 28, and 30, broke up at all gaps. Swapped to ngk 6510 gapped at 30 and breaks up. Boost is around 15-16lbs. I might buy brand new brisk plugs and give that a go. The original brisk plugs were all orange from the torco, I'm assuming.
beefcake
Bethel
2018 Ford Mustang
that won't hurt them though, at 15-16, i would be around the .25, that should be ok
what did lund say on the logs? any knock?
you could always try going extreme like 20-22 just to be sure
Phils15GT
Albany, NY
Sometimes it adds 2 degrees and every once in a while it will pull as much as 8 degrees. Usually it will pull crazy timing if I floor it from about 3k rpms, but if I start the pull at 4k, its fine. Weird?
