Interior map lights not responsive
Thegipper
Orange County, CA
2020 Mustang GT PP1
It this normal?
I turned off the car completely; meaning no accessory mode or anything. I sat in the car with the doors closed, but unlocked for about an hour.
When I opened the door the lights didn’t turn on and the cluster and navigation screen were also off.
even pressing the map light buttons didn’t turn them on. I had to turn on accessory mode for it to work. Is this working as intended?
Thanks
Emilbadal
Socal
Emil
2016 V6 Auto DIB
Your battery voltage may have dropped below 11v during your stay in the car, that way the car goes into battery saver mode, which most of acc elements don’t work until you start the car or turn on the ignition
Thegipper
Orange County, CA
2020 Mustang GT PP1
Hi. Thanks. It’s possible. But it started working normally after I turned accessory mode on then off without the engine ever being turned on, so the voltage should have been (slightly) lower.
