Bartly
Is the 5.0 in our GTs an interference or non-interference engine? Just wondering, reading the factory instructions for setting the timing chains and if I recall it has you rotate the crank a revolution with one of the cam chains off the car. I would have thought rotating the crank without the cams hooked up would cause the pistons to hit the disconnected sides valves. Mostly just curious if anyone has some good technical info why or if I have something mixed up.
Thanks
Thanks
