2018 manifold upgrade + tune. Future proof with 47 lb injectors if you want to run E85. You can run it with locked out IMRCs but tuners have gotten the hang of making them work properly, so I'd get the pigtails to run them active.I cant decide what to do to repair this. New manifold, used manifold, upgraded or supercharged...... wasn't expecting to mod so quick. Ran a compression test before pulling the manifold and the engine seems in decent shape.
I have to think carefully with my mods since I'm in CA with CARB restrictions. Havent researched yet how smog works with a tune etc.2018 manifold upgrade + tune. Future proof with 47 lb injectors if you want to run E85. You can run it with locked out IMRCs but tuners have gotten the hang of making them work properly, so I'd get the pigtails to run them active.
No, you have some kind of mechanical issue with the engine. I'd do a cylinder leak down test.Yeah definitely do. I need an air oil separator
Oil in the manifold is common without an oil separator. @Livernois Motorsports has CARB EO tuning FYICompression test was good and looking on YouTube I see similar messiness on some vehicles so I dont know. I will get this fixed and do a leak down.
Excellent I will give them a call tomorrow to see what my options are. Thank you!Oil in the manifold is common without an oil separator. @Livernois Motorsports has CARB EO tuning FYI
Oh I see what you mean now. I think it's just the pics. Not sure why it wont close. If I close it by finger it closes fine with no resistance but if I use the actuator it will open (close the air space) and when released it stops partially before closing all the way.Hopefully it is just the pics that make it look like the carbon is what is keeping the valves from closing.
Why won't the valve close?
I went back and examined it. All the build up you are seeing is under the flaps. When closed it looks like it's a very light film of oil.Probably have a bad actuator.
Here is what a healthy 78,000 mile 15 coyote intake looks like. No oil separator used.
Dude went with a CJ manifold.
