Installed Both Sides Ford Performance Catch Can at 21,000 miles
Ardy
Vancouver
2019 Mustang EcoBoost
I have a 2019 EB and I just installed Ford Performance catch cans on both sides of the engine.
Do you think there has been significant carbon buildup on intake valves in 21,000 miles?
Also, what's the benefit of doing this rather than just venting it to atmosphere and plugging off the intake holes?
Thanks
FreePenguin
Ohio
Donald
17 mustang
you're fine, dont stress it. people have 100s of thousands of miles with no issues. its just preventing and peace of mind is all you get
VegasEcoboost
Las Vegas
Tommy
2015 Ecoboost
Venting to atmosphere just means you’re gonna have an oily mess under your hood. The can is there to capture oil…. Where did you think the oil was gonna go if you don’t capture it?
carguy231
SoCal
2017 Mustang GT
Why, into that $250 catch can of course... LOL
Seriously, I checked mine the other day and the passenger side had around 1/8 to 1/4-cup of oil in it and the driver's side was bone dry. This in around a 1000 miles on the street.
FreePenguin
Ohio
Donald
17 mustang
gt's ares opposite from what I understand
passenger on ecoboost is clean side, driver is dirty
gt passenger is dirty, driver is clean.
Ardy
Ardy
Vancouver
route hose to ground?
Cheo
Arizona
Mustangs
FP catch can after 6 months and last oil change, did run a few autox since. Can is big so probably no issue waiting between oil changes to empty it.
Elamcup
Kingsville Maryland
Thomas
2022 Mustang Ecoboost MT-82, Chassis N0078
Thanks
Hey Ardy, Are you collecting oil in both seperators?
FreePenguin
Ohio
Donald
17 mustang
don't waste your time on the clean side catch can, not worth it, it throws codes, and it just makes engine not run right.
only do dirty side, I caught oil in dirty side (albeit little) its still worth it there. no issues.
Elamcup
Kingsville Maryland
Thomas
OK, so which side do you collect oil in? The driver or passenger side.
Elamcup
Kingsville Maryland
Thomas
driver side. thats the only one you should get one for. wont throw a code or anything. the passenger side is one you dont want.
Cool, Merry Christmas!
Andrew@Lethal
West Palm Beach Florida
Andrew
Thanks
It's best to run a UPR dual valve catch can on the passenger side of your ecoboost. It keeps any kind of oil sludge from going into your turbo. On my ecoboost I also gutted the PCV valve on the drivers side. I noticed the car ran a lot better after doing so. Kept everything clean. Also keep in mind to empty the can preferably ever 3k miles when you change the oil. UPR Products 5030-104-1 2015-2017 Mustang 2.3L Ecoboost Plug-n-Play Dual Valve Oil Catch Can (Black) (UPR-5030-104-1)
Elamcup
Kingsville Maryland
Thomas
I hope Ardy chimes in on this. I don't have my car yet so I am just making an educated guess here about the Positive Crankcase Ventalation system.
The PCV line to the valve cover with the solenoid valve is probally connected to the compressor intake pipe. This is the line that clean air is drawn into the engine block. So in theory only condensation will collect in that seperator. However when the crankcase is pressurized and if the solenoid hasn't snapped closed then the crankcase oil vapor could backup into the intake pipe and coat the compressor wheel.
The PVC line on the drvers side connects between the engine block and intake manifold. Under vacuum the oil vapor and byproducts of combustion will be sucked into the intake manifold to be burned. Oil should collect on this side of the engine. Does the PVC line have a check valve to prevent over pressurizing the crankcase and the oil seperator?
