indoor storage
bergdon
GA
Robert
2016 Mustang
Another vote for cleaning the car before using the cover to prevent unwanted micro scratches.
TasGT
Launceston, Tasmania
2016 MY17 Mustang GT 5L Triple Yellow Convertible
Check out CoverCraft also.
The cover will not necessarily be packaged from the factory in the manner that makes sense in this process, so get someone to help you to put the cover on the car first.
This is the process I do to take the cover off, this then sets you up to put it back on safely and efficiently.
Go around the car and unhook from the bumpers.
Then fold the sides into the middle of the car.
Then roll the cover up from back to front, resting the roll at the base of the windscreen, then roll the rest from there and lift off the car.
Now, putting the cover back on is a reversal of the process. Rest the roll at the base of the windscreen, roll out from front to back, fold down the sides and tuck back under the bumpers.
Same method I have always used too 😄👍🏻
Rapid Red
Woodstock GA
Greg
Francois: I'm sure every person who has used covers regularly has their way of doing things and the vehicle plays a big part. To my mind, there are only a couple different starting points as you said for a Mustang.
I unhook the front and roll up to the windshield. Then unhook the back and roll to the mirrors. Pull off the passenger side mirror section and roll forward. Finally, over to the driver side, pull the mirror, roll firmly, then flip the whole thing partly over itself and roll like a sleeping bag. I set "the roll" such that I'll know how to pick it up to unroll.
So, if anyone has a quicker method, I'm all ears because when it's covered, it's the uncovering that often keeps me from driving the car. :-)
LOL that is the quest, and close to my dance.
Front and rear unhooked. Flip up the driver side, go to pass side pulling the cover to that side of the roof. Then bring up the pass, side laying on top. Alien with the back edge of the fold from the drives side (does not need to be perfect).
Still working from the pass side fold again. Creating a width about the size of a sleeping bag, cover is still full length F&R.
Go to the front and roll to the back.
To install sit the roll in the middle of trunk. I bias it to the driver side. Roll forward, first unfold is from the driver side to the pass. Back to the drivers side, unfolding the cover. I will capture the mirror in the pocket, keeping the cover anchored.
Go to pass side unfold, do the same with the mirror and pocket.
To the front fluff the cover like a bed sheet. Allowing the sides to completely drop, hook the front, repeat at the rear.
I find some music of one's choice, promotes the dance step for success.
Cheers,
Greg
Hoofer
Western Wisconsin
Boz
2020 GT Vert, PP1, MagneRide, ActiveExhaust, B&O
I do not use a cover. Over the winter, its stored in a car capsule. Otherwise, it sits uncovered in the garage. I use this to remove dust and love it:
https://www.griotsgarage.com/product/microfiber+car+duster.do?sortby=ourPicks&from=fn
BTW: Talk all you want about the duster creating micro-scratches. Yes it does create microscratches.
Remember, every single time you touch your car, you scratch it. Whether you wash it with a mit, put a car cover on, use a microfiber cloth, or use a microfiber duster. You scratch it. Period.
Rapid Red
Woodstock GA
Greg
Nonsense, that's smoke, paint is not that weak. Common sense care will provide the owner with a lasting finish.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
Boz: I have to respectfully disagree as I am of the same opinion as @Rapid Red.
Having said that, I will agree that putting a cover on a vehicle that has ANY contamination on it be it dirt, dust, or whatever, has the potential to mark the clear coat. Consequently, the only time I cover mine is after a wash, no other time. Equally important that probably goes without saying but one needs to keep THE COVER clean, too.
But, if I want a really clean car (when it's "dusty,) I will use a couple MF towels and a bucket of warm water and a drop or two of soap. Wipe down and wipe dry. If you do this, when you see how dirty the water in the bucket is, you can understand why contact with contaminated clear can cause issues.
Rapid Red
Woodstock GA
Greg
Pictures worth thousands of words, raining out, nothing to do
Uncover and store
Rapid Red
Woodstock GA
Greg
Cover up, satin cover protects the paint.
Simple never get the front and back mixed up
kilobravo
Corpus Christi, TX
kilobravo.com
KB
Greg: I'm going to presume that you've experienced this with the soft cover but in case newer owners have not, here's the tip. The soft cover is EXTREMELY hydrophyllic and they STAY wet for a VERY long time, even when put through a dryer cycle..or two. Then, if you happen to miss this fact and install the cover, there will be big old wet marks on the car the next time you remove the cover.
I imagine that keeping it dry is fairly difficult where you are in Georgia with rain and the resulting humidity. I know it is down in my part of the country. So, the key is, keep it as clean as you can so the washing frequency and resulting drying quest are minimized.
Rapid Red
Woodstock GA
Greg
Parked in a covered breezeway.
AMC401V8
Kentucky
2020 Mustang GT - 2000 Excursion - 1987 Swift DB2
Over the years I've come to the conclusion that what is best for me is NO cover. It stays inside in a climate controlled environment, however. I've just had too many covers cause too many problems, though others disagree.
