In a pickle
SazMayo
203 Connecticut
2020 GT Premium 6spd
So I could use some help. I have a 2020 GT, I installed the 350r big brake kit (https://performanceparts.ford.com/part/M-2300-Y) and it looks so damn good. But my wheels don't fit.
Current wheel package
Front - 20x9 ET 32
Rear - 20x10.5 ET 42
The rears will fit with 3-5mm spacers, rear of the caliper clears as well as the width. The fronts do not fit and if i use a spacer my current wheel with its offset would just poke out so much it would look terrible. So i'm going to have to get new wheels and tires which is fine but my question is if anyone has done this to their GT and what they did for a wheel upgrade from stock. I assume if I just get GT350r wheels they will fit but im unsure about the fitment (look). I don't want it to poke too much past the fender since the 350r wheel package is Front - 19x11 Rear - ET 24 19x11.5 ET 56.
Any help would be greatly appreciated!
NightmareMoon
2016 Mustang GT PP w/ Voodoo
It shouldnt be hard to find a wheel that fits. Actual 350s have a bit more front fender clearance than GTs but it sounds like you may have bought an unusual wheel design for a mustang? A 20” barrel is wide enough, so uou must be having trouble with the face design of your wheel.
Most aftermarket wheels which fit a GT350 should be fine for you. If you had camber plates you could likely fit virtually any GT350 compatible aftermarket front wheel.
