I think I messed up my car guys- Urgent help needed!!
Ghostrealm
Ghostrealm
Here
17 Triple Yellow Mustang Convertible Fully Loaded with GT body package, 2002,Black WS6 Trans am Ram Air (winter car) First car 2000 Laser Red Mustang GT
I just need to know what tabs need to be moved on this here circled
Ghostrealm
Ghostrealm
Here
Btw all fuses including 36 were fine it was this maxi fuse that was blown. The three bolts in the picture were easy to remove. Whats left is the maxi fuse stuck in the fuse tray and wont budge. I was trying to use pliers to pry the entire thing out it wont budge. It's held in with clips i think from the side? Does anyone know from all the experts on here how to remove this maxi metal large fuse? I will just put the new one in and should solve all my issues hopefully.
Ghostrealm
Ghostrealm
Here
Test continuity between the red and green arrows and the red and blue arrows.
It was blown. I cant figure out how ro take this darn piece out.
CarbonZ
Raleigh, NC
2017 GT350
I havnt removed it b4, but a quick search said this. Id link the post but my clipboard froze up so just took took a screen grab. Not sure if that will be helpful or not though. GL
Ghostrealm
Ghostrealm
Here
Does it say where to put the screwdriver in so it releases? Can someone highlight where on the part to stick the screwdriver in? Thx so much guys.
I messaged this guy a few weeks ago he never wrote back to me.
CarbonZ
Raleigh, NC
2017 GT350
Not that I saw. I'd imagine it's just pinched in there and the screw driver just releases the tension. No idea though as I havnt looked at it.
I woulda guessed looking at the replacement would make it obvious, but I guess it's not.
Sorry I can't be of more help.
Ghostrealm
Ghostrealm
Here
Noone else here has replaced this ? Is this a magical part? lol
Ghostrealm
Ghostrealm
Here
Here are better angles of it. I was even trying to pull it out with pliars grabbing the posts. It wont move
sk47
North Eastern TN
Jeff
Hello; two thoughts. One is to have a good look at the new replacement part to see if it suggests tabs or such which may need to be released. I slightly doubt that is the problem but have not done this so do not actually know.
My second thought is when the part blew out (shorted out?) a lot of heat was generated and perhaps the plastic portion of the part may have melted and flowed some. If such turns out to be the case, it may be difficult to remove the smaller fuse block. May also damage the entire fuse assembly. I get this could be a daunting and potentially expensive thing if that entire fuse block assembly needs to be replaced. Keep in mind this is just an unsupported guess.
good luck
EDIT- looking at the new part pictured I do not see any serious tabs which might make removal difficult. The part has three sturdy nuts and on bolt which ought to hold it in place. That is why the melted plastic thinking.
Ghostrealm
Ghostrealm
Here
I did notice the bolts especially the battery bolt was really really tought to remove. I didnt see weld marks on the screws after I finally removed them?
sk47
North Eastern TN
Jeff
I did notice the bolts especially the battery bolt was really really tought to remove. I didnt see weld marks on the screws after O finally removed them?
Hello; This is unknown territory in my experience. I have done work on a positive ground car ( an old Jaguar) but have never reversed the polarity of a battery and driven a car. That the car started with the terminals reversed is of interest. I would have expected a dead short as soon as the terminals were connected.
I am following this thread to learn about the issue, but do not have much in the way of advice. I hope you figure this out and report. Again good luck.
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
good luck
Yeah, that thing probably got really hot with hundreds of amps (momentarily) flowing through it. It may be melted on the back side.
Ghostrealm
Ghostrealm
Here
I think I just need to know how this is properly removed before I we believe its melted on. I have a feeling it is a point on the clip that needs to be depressed. It feels loose to the touch but held in place by something. If it was melted on I dont think it would wiggle?
Torinate
Ontario
2016 GT Convertible
It looks like you would release the tab at the back of it. I tried zooming in to see but it was grainy. Have a higher def pic? I’ll pm you my cell and you can send it to me. Just got in...
Torinate
Ontario
2016 GT Convertible
Ok. The tab is at the back where my red arrow is. Push it back and pry slightly from the backside and it should pop out.
Pick of my car...
