HOW TO: Install LED Digital Carbon Fiber Steering Wheel
ohnoitstino
Toronto
Ru
2019 Mustang GT
Did you ever figure this out? I have the same problem with mine and it's driving me crazy.
Yeah! Just plug it in the same slot where the tutorials told you. Mine worked
m3incorp
Georgia/Colorado
James
What info is shown on the steering wheel screen and is if useful if the screen is not at the 12:00 position.
Calibando
Md
Greg
2019 Mustang GT Premium A10
So I had the same problem, my solution was splicing them, I used one of the yellow wires to the clock spring and the purple and white wire on the bottom, that’s one of the pass thru connections, and what I’m currently using until a problem occurs....
s550_kratos
Belleville, NJ
Manny
18' GT Premium Lightning Blue
Where did you ground?
Joshua.Journet
U.S.A
Josh
Mustang GT Premium 2020
can anyone help me out i have a 2020 mustang GT Premium and im following what everyone has been saying but my both plugs have a wire in the 2nd slot were it says to insert the red wire and the white. also were do i put the ground wire? plz help ive been on this for 3 days now
AequitasVeritas
AequitasVeritas
Southern California
Paul
2017 Mustang GT Premium
I clarified the instructions a little and included how to attach the ground wire.
If your Pin 2 is occupied on 2020 is there any that are still open? Do you have a heated steering wheel?
koryunaren24
Los Angeles
2018 mustang gt premium
Any fix for this? Did you find it.
koryunaren24
Los Angeles
Do you have more pictures of the wiring? I need to do the same. Do you know what the pink wire was used for before you spliced into it.
coyote._s550
Germany
Hasan
17 ecoboost/19 gt
So i have 2019, heated steering wheel, digital dash. All of the pins are occupied so i had to improvise because nobody has posted here or anywhere not even YouTube video and i came up with this
connect the white wire from the obd into the purple on the clock spring located under the steering wheel.
Connect the red wire from the new steering wheel into the two yellow wires in the main connector on the steering wheel
Now connect the ground wire from the steering wheel into any metal part. I connected it to one of the screws in the steering wheel just make sure it touches any metal Part that is grounded.
you don’t need to connect the blue wire anymore for this method
with this method will be having one problem which is that light of the steering wheel will not turn off unless you unplug the OBD connector, i will Find a solution for this but in the main time I’m happy with the results
The steering wheel will turn on itself when you turn on the car and it will turn off when you turn off your engine
coyote._s550
Germany
Hasan
17 ecoboost/19 gt
C218b
Clockspring connector
Steering wheel side
