How to get NGUAGE to show AFR not Lambda
Scott Wilson
s550 is life
Central TX
Could anyone help me with this. I didn't see it in the guages and my buddies 13 shows AFR on one of his gauges
Jn2
Austin, Texas
Mustang GT
Keep it set to lambda, that is what you actually want to see when datalogging and driving the car. A/F is pretty useless since the tune is written with lambda in mind.
Also variance in ethanol percentage from pump to pump will change the A/F the car displays via cluster gauges, but lambda will stay consistent since stoich is always 1λ. This is even more important when you start running flex fuel or e85 tunes.
Scott Wilson
Scott Wilson
s550 is life
Central TX
But the conversion is only a calculation and it's easier to read AFR on the fly then a fraction.
Jn2
Austin, Texas
Mustang GT
Lambda is much easier to reach bc it is only 2 numbers that do not change regardless of how much ethanol is in the tank...if your WOT lambda is set for .83/.84 then it will show those numbers regardless of how much ethanol you are running at the time.
Maybe this will help with your initial question:
[ame]
higdominator
Central Oklahoma
2016 GT PPP
You are spoiled by that Accessport, lol.
That being said, reading lambda is much easier, especially if you go flex fuel/E85. It took me a few weeks of looking and doing the quick math to get back to readily reading lambda. Now it's cake, and no need to worry about E stoich points with the changing E%.
  • Like
Reactions: Jn2
Scott Wilson
Scott Wilson
s550 is life
Central TX
I am. Being from the import community we dont use lamda. Im kinda figuring it out but damn im constantly pulling out my calculator on my phone.
higdominator
Central Oklahoma
2016 GT PPP
I did that too. I finally have figured out the range I want to be in, .795-.820. It gets easier, especially after using the gas scale then getting used to just reading the E-stoich scale. It gets easier, lol.
