How to avoid clunking noises when downshifting
GPGT17
Gene
17 GT PP
some days are good some days are bad. Down shift normally easing out the clutch also downshift with rev matching. Still getting used to this MT82. With radio off is all the clunking normal?
2017GBGTPP
Albuquerque, NM
2017 Grabber Blue Premium GTPP w/ Recaros
Pretty much. The MT-82 is famous for its clunkiness.
iSpeed27
Dallas, TX
2016 DiB GT
^ Yup. I consider myself lucky. Mine didn't start to clunk until a couple weeks ago after I hit 47k miles. Weird part is, it only happens when I have the a/c running.
GPGT17
Gene
17 GT PP
I’ve always ran the ac, I’m going to run without and see what happens
Zrussian13
Phoenix
Interesting... what clunking are you guys experiencing? If I'm really sloppy with a lower rpm down shift I guess a little clunky would describe it but 99% of the time it feels real crisp on the downshift...
ChromaticGrey
Nevada
Grey
2017 Mustang GT PP1
The transmission itself makes clunky sounds all the time unless you are matching speed/rpm clutch/ in out well. There is a lot of rotating mass that has to match up, and if they're off, there can be noise and rattling. Trans, engine, and drivetrain all leave a lot of noise to be made. Mine can make a lound clunk sitting at a stop, when you clutch in and put it into first. Also when clutching in at low speed when load is on it(either slight accel or decel), once pressure is taken off the drivetrain, clunky, clatter, clunk.
I also was concerned, it is the noisiest MT ive driven. Its also the most powerful car ive owned. Its also the only mustang ive owned.
Its a mustang.
nastang87xx
San Diego, CA
2016 GT350 Track Pack
What you're mainly hearing is the two piece driveshaft as well as a tiny bit of play that's in the output shaft. 100% normal.
But a smooth well executed downshift even if you're not rev matching shouldn't be overly abrupt and noisy.
JohnD
Legend in his own mind
beyond the pale
2023 Mach 1 track day car
If you think it's bad stock you should hear it when you put in black poly bushings throughout the drivetrain and rear suspension. Now that's clunking with a heapin' helpin' of diff whine (actually it howls at times) thrown in for good measure.
Ghost50
Houston by way of Philadelphia
2019 Magnetic Metallic GT PP1
I’ve got the diff bushings and motor mounts and I don’t think mine clunks too much. It has gear whine but that doesn’t bother me. I usually only hear it if I’m focused on listening for it.
I actually think the diff bushings and motor mounts helped reduce the sloppy clunkiness that the stock set up has.
My first main goal with the car was to stiffen the driveline. The one piece drive shaft will be one of my next mods. That’ll just leave the clutch as my weakest point.
