How often do you empty your catch can?
Michele_Italy
Italy
Mustang Ecoboost MT
Dear all,
I have UPR dual valve catch can, with PCV valve gutted
Just after 150/200 miles is already half filled.
I made a lot of pull in this period because I was still tuning my car.
My car is FBO with vergas stage 2, E30, 25 psi
Is it normal to have found so much oil?
Don't forget I gutted the pcv valve
Thanks
TorqueMan
St. Jacob, IL
2017 EcoBoost Premium
Dear all,
Thanks
It's hard to say. I suspect each car is a bit different depending on boost settings, how well the engine was broken in, etc. The factory PCV system incorporates an air/oil separator that returns oil to the sump. If you have bypassed that system then all the oil that used to return to the sump is now going into your catch can. You will get more oil through the PCV plumbing when running the engine at higher power. Does the installation instructions that came with the catch can recommend gutting the factory PCV system? If so, I would contact UPR with your question. They should have an idea of what you should expect from using their product.
Elgyn
Vancouver, Canada
2016 ecoboost, MT, DIB, Premium, PP
roughly every 3000km. I get maybe 45cc of oil/condensate
5.0yote
AKA Bananana & 3.7Cyclone
Mansfield, MA
www.youtube.com
Don
2016 Mustang Ecoboost Premium
Every oil change, with temp changes and driving condition changes you can have different volume levels during different times of the year so.
PRG3k
Orlando
Turbo
On my original factory block with cylinder 3 on its way out, on E30, boosting it every day, I used to drain 1-2 oz out every 1000 miles. On my rebuilt bottom end I do it every oil change and there's 1 oz in there at the most. I don't punish it nearly as hard as I did before. Its going to depend on many factors: mods, boost, and abuse. Half full after 200 miles seems like quite a bit.
EcoBoostang
2015 Mustang Ecoboost Premium
I’m in the same boat here... 2500-5k miles. Depending on oil changes.
Weather Man
Persistance is a Bitch
MN
2015 I4 T Prem Auto
Every 2,000 miles.
H@mmer
NE Georgia
2017 GT w/ Too Many Mods
Oil Change.
ForYourOwnGood
Central MA
2017 Grabber Blue 5.0
When I had the EB mine was almost full every 3000 miles when the oil was changed, worse in the cold weather.
Michele_Italy
Italy
Mustang Ecoboost MT
thanks for you answers
Maybe I abused my engine a lot in this period
Now I will try to keep a slow ride for 1000 miles and I will check oil q.ty in the catch can
