How can I crank my engine?
StangATX
Project Corrupted Cyclone
Austin, TX
2016 S550 White Corrupted Cyclone
Hey everyone!
Quick question... How can I crank my car? :D Since we don't have a key it's kinda hard to crank our engine now. I'm about to change all my belts and I heard after I used the ratchet to crank my engine manually and replaced the belt. I have to go and crank my engine with the key before to really start it... Kinda screwed on that one :lol: Any ideas?
Thanks!
Tobey
16 Vert
? I don't completely understand what you're doing, but if you're just replacing the belts, just start it up.
StangATX
StangATX
Austin, TX
Let me try to re-explain myself lol. Whenever you replace the smaller belt (from the AC Compressor to the Crank) We need to use a Ratchet to move the pulley and get the belt IN/OUT. However, once all the belts are replaced. I heard that I have to crank my engine without starting it to make sure the belts are all aligned properly before to really start my engine. The problem is that we can't really crank our engine with that push button...
StangATX
StangATX
Austin, TX
Just start the car. It'll be fine.
If it's not fine, you'll know pretty quickly.
I'll know so quick that I'll be SOL :lol:
fifteen5oh
SOCAL
2015 GT A6
You wont be SOL, worst case belt will slip off, I doubt any catastrophic failure.
Regardless >>>> Tap the start button as if you where starting the car, when you hear it first crank Tap the button again which will stop it from starting. or you can pull the Coil power/ engine power fuse(s).
Glenn G
Kaiserslautern, Germany
Glenn
15 DIB 6MT base Ecoboost
pull the fuel pump fuse, it's how I learned to easily release fuel line pressure or prime a freshly built engine with oil. It will take a few extra cranks to build up the fuel pressure again when you actually want to restart it so make sure your battery isn't weak.
maddawg57
Winchester Va.
2015 Comp Orange Premium PP GT
Better tell OP to put said fuel line back on before he turns it over or we will be reading about his fire.
Glenn G
Glenn
Fuel pump FUSE not fuel line,
If you disconnect a fuel line while cranking the car you will have quite a mess on your hands and a potential fire.
StangATX
StangATX
Austin, TX
Thanks for y'all's ideas. I also heard that if I push my gas pedal all the way it'll prevent the engine to start... I'll give it a shot before to change everything.
StangATX
StangATX
Austin, TX
Well, The gas pedal did the trick! I took a quick video. I'll post it later on. Thanks for everyone's help and ideas!
StangATX
StangATX
Austin, TX
[ame]
GTBOB
Fairfield Township, OHIO
Bob
'18 GT, Royal Crimson, 10 speed, Active Exhaust
Yep. When you floor it while cranking, the ecu turns the fuel injectors off. Great procedure for cleaning out a fuel-flooded motor.
