Passenger side PCV, brake booster and evap purge solenoid all route to ports underneath the manifold. It really is that simpleI am in the process of installing my Holley Sniper. I was wondering if anyone had pics of the vacuum setups. I am planning on being boosted, so if you have suggestions, that would be much appreciated.
Detrick
Yes,So, I ordered the Holley throttle body spacer required for stock throttle body and it doesn't fit. It is shaped exactly like the opening of the intake, so it interferes with the porttion of the throttle body that sticks out. I have seen pics of the spacer on others, and the adapter is smaller. Did anyone else run into this issue?
Did you finish installing this? How'd it go?Thanks. I'll have to call them up then.
