Highest quality supercharger kit?
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
Except it's misquoted. It often is I don't know why lol.
As for quality, fit, finish, etc it's tough to beat Whipple, KB, or Roush. They all make quality kits. My personal preference is Whipple since I've used them before and had great success.
I got his point but in my head I was thinking "I'm your huckleberry" [emoji57]
proamas
Tampa, Florida
2015 Mustang GT 50 Year Package
Beefcake is right, all can get you what you want. Just comes down to pers nap preference. As you can see we are all slightly biased as to what we have on our cars. ;)
Sinister
Missouri City, TX
2015 Black GT PP
John S.
Valrico, Florida
2015 GT Premium Performance Pack
Sounds good, I'm down in Westchase. I'll private message you and we will see what we can do. We can get pics, side by side and some test hits
I'm in Brandon with a stock GTPP and can be the unbiased opinion of the two cars. I'll even bring my camera. :thumbsup:
DrDing.Muscle
Hampton, VA
Tyler
2015 Premium GT PP Competition Orange
Doesn't the motor have to be lowered some for the Kenne Bell setup to clear the hood?
proamas
Tampa, Florida
It does yes. The Billet motor mounts are included in the kit and are significantly stronger than stock.
Stage_3
MA
2019 Roush Stage 3
I do believe you are correct here.
I think the KB kit comes with a pair of motor mounts that lower the engine some.
proamas
Tampa, Florida
Correct.
DrDing.Muscle
Hampton, VA
Tyler
That seems like a pretty extreme step to have to do. Does this change things like the angle of the transmission which in turn changes things like pinion angle which can affect universal joints and other things?
proamas
Tampa, Florida
Takes a half hour at the most, tops. They are stronger than stock and a much better piece. Remember we have two piece drive shafts, also it doesn't change the angle very much at all.
jayman33
Fort Bragg, NC
Jason
24 GT
Two piece was built around cost and lower NVH, you still need to correct the pinion angle if you alter it. More so for the rear of the car than the front.
Any of the kits I think you'll like, we can do full custom kits for Roush, Vortech, Whipple, VMP and Procharger. You can use any tuner you'd like as well for these kits, the tunes that are coming from the companies arent too bad, conservative but safe.
Again, its all in preference really.
Travis@boostworks
Katy, TX
www.boostworks.com
2015 Mustang GT
People have been installing drop mounts in Mustangs for 15 years.. It's a non-issue, and you get a stronger billet/poly mount in the process. It's included with the kit, and takes 15-30 minutes with a lift, or on the ground.
Jak112460
AZ
2015 Mustang GT
Heat Soak
I'm curious about heat soak in the Whipple type blowers. I have two shops here in AZ that claim the Pro Charger/ Vortech style blowers suffer less temp fluctuations. Can somebody address this?
tea cups
Colorado
15 WRX
Sounds more and more like the Whipple is the highest quality kit (by my criteria). Roush /FR kit requires some grinding/cutting of front cover of motor and also there's been some reports of intermittent loss of power on the included tune. Can't find any details about the Kenne Bell install or driveability, but the additional step of having to install motor mounts over the Whipple is a knock against it and someone mentioned the fit and finish isn't as good. My criteria is probably a lot different than typical. I'm willing to make less power to get a higher quality part/design and better reliability/driveability with least chance of issues.
Jmeo
You said member ;)
Massachusetts
Jaime
Honestly KB has great fit and finnish. They also use high quality parts and have great reliability. This all needs to be noted but to me they, out of all other kits combined, look the furthest from OEM. Not meant to be a knock on them, it's just you mentioned this is important to you. The motor mounts are no big deal actually but I get where you are coming from.
When it comes to OEM integration and looking like it was installed factory in my opinion Whipple takes the cake. No cutting, hi quality parts and looks like it came that way from the factory.
Vortec and the like look great and I'm sure use great parts and have good reliability, they just don't look OEM.
I am only talking about looking the most OEM here and I am not factoring in anything else as this is what seems the most important to the OP.
