So you're telling me I can't spin my 7.3 to 6500+ RPM? :lol:
At least not without probably $100k is machine work...
I'm not trying to bring 7.3 specific logic here, I realize they are totally different animals, but don't knock me for trying to learn new things and expand off of the knowledge I do have. It's what I know, and I'm trying to learn new things based off of that. Just like multiplication is a totally different beast than simple addition, but similar concepts apply, hence why in school you learn addition, then multiplication, you build off what what you have. I realize that one is a low revving work horse truck engine meant to pull heavy stuff over long distances, and relatively speaking is a dinosaur technologically, whereas the other is a high tech, high revving, basically race engine meant to propel a small car at high speeds. However they are both computer controlled engines, so some of the same type of programming ideas may be similar, such as beginning to limit fuel/spark/cam timing etc before the actual hard limiter. All I was doing is trying to throw a different idea into the mix, maybe something that not many people have thought of. Long stretch but things like that can happen. There has been numerous times that I have been stumped wrenching on a vehicle (my hobby that I've been doing for 14 years, so I'm pretty experienced) and someone like my girlfriend points out something or has an idea that is so simple that for some reason I never thought of that helps or even fixes the problem.What I meant was don't bring your 7.3L logic to a 2015 mustang forum. No it doesn't make power up there without a manifold swap. It's been known in this forum for 2 years. If you want to run a manifold tune with a stock manifold go right ahead, good luck picking up your engine parts off the road.
If it gives you closure.....from my brief looks at my datalogs I don't see a drop in timing up stop, it stays steady til the shift point.
It's mostly the manifold it has fairly long intake runners Tuning helps a little as does a very free flowing intake tube and filter. Stock Soft limiter is 6850 and full cut is 7000 so 150 rpms there. Power peaks at 6500 and drops pretty hard after that. First mod I did was a tune and it definitely woke the car it.I know this is an old thread, but I have a point to bring up regarding power drop off after 6500 RPM. Has anyone ever ran a higher RPM tune (such as the one for the boss manifold) with a stock manifold? How do we know that the manifold itself is actually what is causing the drop off in power rather than factory tuning? I'm no expert in tuning but I do know from talking to the guy that did a live tune on my 7.3L Power Stroke that factory tuning actually starts cutting power a bit before the actual rev limiter. It isn't full fuel until 3500 RPM (in the case of my 7.3) then *bam* rev limit, it actually starts a gradual cut out a couple hundred RPM before the hard one.
So basically you are saying that my line of thinking is somewhat correct? That the manifold only itself is not the whole reason that power drops off dramatically after 6500? That the tuning does play a role in that?It's mostly the manifold it has fairly long intake runners Tuning helps a little as does a very free flowing intake tube and filter. Stock Soft limiter is 6850 and full cut is 7000 so 150 rpms there. Power peaks at 6500 and drops pretty hard after that. First mod I did was a tune and it definitely woke the car it.
My car as it sits with 1 7/8" long tubes, no cats, straight through mufflers, a Pmas intake and my own custom tune with a 7500 rpm limiter pulls noticeably harder than stock up top especially from 6500-7400 (my shifts are made around 7300-7400 now) but honestly most of that is the big primary LTHs and extremely free flowing 5" Pmas intake my tune made a bigger difference in low to mid power and drivablity. It still doesn't quite have the top end that my 13GT had with a boss 302 manifold.
You are somewhat correct as a very free flowing exhaust, intake tube and filter and some tuning changes absolutely make a difference in top end power from 6500-7400 with the stock manifold but stock manifold doesn't compare to a GT350, Boss 302 or Cobra Jet manifold for power above 7000. Unfortunately it's just the flow dynamics of a longer runner manifold with a smaller plenum volume vs a shorter runner intake manifold with a larger plenum volume.So basically you are saying that my line of thinking is somewhat correct? That the manifold only itself is not the whole reason that power drops off dramatically after 6500? That the tuning does play a role in that?
What I'm getting at is that sure, maybe the manifold is restrictive above 6500, and does cause power loss, but is that the ENTIRE reason for the power loss, or is the tuning part of it? Sorry if I sound somewhat repetitive, just trying to convey my point with zero doubt as to what I mean.
We still beating the horse? "I don't feel like researching anything, just tell me I'm 39.5% correct."
There's a dyno sticky at the top of this section, shouldn't take more than an hour to go through it and look at different dyno sheets with different mods.
Wait what...a stock manifold makes your engine blow up at 7500? LMFAO! Guy immediately gets on here to bash then makes up his own facts. 7500 RPM will not benefit a stock manifold what-so-ever, but your engine wont blow up from it. In the time you wasted bashing the guy and repeatedly telling him to do research, you could have just answered his questions. Do everyone a favor and get off the forums if you're gonna bash and be completely unhelpful. :headbonk:What I meant was don't bring your 7.3L logic to a 2015 mustang forum. No it doesn't make power up there without a manifold swap. It's been known in this forum for 2 years. If you want to run a manifold tune with a stock manifold go right ahead, good luck picking up your engine parts off the road.
Congrats, you win at picking a few words out of several posts to try to make a point which really has nothing to do with what I said. And bashing? A little thin skin if you think any of that was bashing.Wait what...a stock manifold makes your engine blow up at 7500? LMFAO! Guy immediately gets on here to bash then makes up his own facts. 7500 RPM will not benefit a stock manifold what-so-ever, but your engine wont blow up from it. In the time you wasted bashing the guy and repeatedly telling him to do research, you could have just answered his questions. Do everyone a favor and get off the forums if you're gonna bash and be completely unhelpful. :headbonk:
Telling the guy to take an hour to look through a post for his answer rather than take less time than it took for you to type up numerous unhelpful posts was just incredibly inefficient. You must be having a bad day to be willing to waste it here providing nothing constructive. Hope it gets better friend :cheers:Congrats, you win at picking a few words out of several posts to try to make a point which really has nothing to do with what I said. And bashing? A little thin skin if you think any of that was bashing.
Fella revives a 1.5 year old thread talking about if running a tune for a coyote with an aftermarket manifold will allow him make power past 7k rpm but yet claims "I just don't have the time or ambition to search for hours to find information on something I have no immediate plans to do." Im pretty sure everyone that answered said no and he kept at it. At this point Im wondering if I should contact Lund about a GT350 manifold tune for my car. This just might work.Telling the guy to take an hour to look through a post for his answer rather than take less time than it took for you to type up numerous unhelpful posts was just incredibly inefficient. You must be having a bad day to be willing to waste it here providing nothing constructive. Hope it gets better friend :cheers:
Unfortunately, every body is right. The manifold is just not efficient beyond 6.8k, while Yes you can push it further, it feels unnatural to the rngine and out of breath with several different tunes. Once I swapped to the GT350 intake it was very obvious... the car pulled like there was not end. So I got ambitious and went for a 8k Redline... perfect combo there. Now with the procharger on top of it, I wish I could push it to 9k, lol. Not chancing an engine tho.Well that answer is all I was really looking for, but with some data to back it up. I'm sure it's out there, I just don't have the time or ambition to search for hours to find information on something I have no immediate plans to do.
