Help with Steeda caster/camber plates
codereddew
2019 Mustang GT PP1
About to install some Steeda caster/camber plates.
I’m a noob and never installed c/c plates before so forgive my ignorance, but what are these extra plates for (circled in red).
All of the installs I’ve seen only use one of these plates placed between the top of the plate and retaining bolts.
Do I need to use these extra plates and if so, do I just place them between the top of the plate and retaining nuts or do I put one on the underside of the plate (see pic with red arrow)?
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
About to install some Steeda caster/camber plates that I purchased used.
Did you also order the adjustable front ride height kit?
pm your contact phone number and I will have one of our techs reach out to you.
Thank you
Steeda tech
codereddew
codereddew
2019 Mustang GT PP1
Thank you
Steeda tech
Ok
okay PM’d
codereddew
codereddew
2019 Mustang GT PP1
In case anyone else comes across this thread, found out that the other plates are spacers if you want to raise your car, so not needed for a typical install.
tj@steeda
Timothy
SteedaTech to the rescue - customer service!
If you need anything further, let us know!
TJ
Brad2016
'16 Mustang GT PP
Are these easy to adjust once mounted?
2016 Mustang GT PP w/ Voodoo
Yes, they're easy enough to shift once mounted - but knowing how your toe has shifted after you've changed camber probably means a trip to the alignment rack, so its not like you're likely to be electing to change settings on a whim.
