Help with Lowering Springs/Struts/Shocks/Alignment
takingws
Kingman, AZ
Brett
2015 Mustang GT 50th Anniversary
Decided to lower my car with Steeda Progressive Lowering Springs and Pro Active Struts/Shocks
Is anybody else running this setup?
Is there anything else I’ll need?
I don’t believe I have a place in town that’s able to align with camber/caster plates/bolts.
Any info appreciated!
Rodpwnz
SF Bay Area
Rod
2018 A10 PP1 401A GT
I lowered mine on FP magneride springs, but it should be the same or similar drop as you.
First, buy this steeda rear camber adjustment kit - you and your alignment tech will thank me. It's on sale for under $150.
Then, you will need to find a performance shop that can align lowered/performance cars. You may need to drive out of town to find a good one, trust me it's worth it. Ask me how I know...
After weeks of trial and error to fix my mismatched and stuck at -2.5(or more) rear camber, and eventually changing alignment shops, and installing the steeda rear camber kit...I'm now where I want to be, which is at -2.3 up front and -1.7 rear. -1/16 inch front toe, 1/16 inch rear toe.
The OEM rear end on mustangs is a royal pain to align properly, if even possible after lowering. The steeda kit I linked solves both issues. Good luck!
pinksurfer
Sin City
Scott
2015 Mustang GT 401a pp1 6sp
I am looking at the same setup. hope to have it after the weekend but will be a month or 2 before I install.
if you need an install/alignment check out kaiju motorsports in henderson. they did a few things on my old 370z including alignment when I dropped it. got it back within factory specs and they will trend toward track align or "save your tires" align depending on what you want. good guys. they are more import but told me they have done some basic bolt on and align work on ford/chevys. they will be seeing mine when the align time comes-self install.
I have a very similar car. should meet up sometime. I come to bhc every month to visit the parental unit.
takingws
takingws
Kingman, AZ
Brett
Sweet! I appreciate the info! I’ll have to call and see what they might suggest with anything to help get it aligned to where I’d want it.
I’m down to meet up! Shoot me a dm! 😎
