Help with codes
KilluminatiDre
Was Chiraq now wonderful Arizona
2015 Mustang GT PP
So my issue is when I start driving right after engine start there is a slight jerking and the brakes feel very weird as if they want to lock with hardly any pressure then the car cuts off ABS, Advancetrac, power steering and the air bag light is on. Also right after startup I get a message saying service Advancetrac.
I finally got a good code reader and forscan. If I scan the ABS and PCM with just the warning message of service advancetrac I get nothing but after the car cuts everything I get these
ODB Link with enhanced options gives me:
P061A-00- Internal Control Module Torque Performance
U0415-00- Invalid Data Received from ABS control Module
Forscan gives me much more
DTC in PCM
P061A:00-68
DTC in FDCIM
U3003:16-AC
DTC in OCS
U0401:00-28
DTC in ABS
U0140:00-68, C0051:67-68, C0039:07-68
DTC in RTM
U0401:00-28
DTC in RCM
U3003:16-08, B00A0:68-08, U0401:00-08
DTC in PSCM
U0401:00-08, U0415:00-08, U3003:16-08
DTC in IPC
P1535:01-08, U0415:00-08, U0415:81-08, U3003:16-08
DTC in GPSM
U3003:16-08
Both ODB Link and Forscan both came up with the U0415 but nothing else in common.
Looking at the logs it seems like most of these are "lost of communication" and "battery voltage" which might be to the car having cut these systems off but something that stands out on the ABS section is the C0039:07-68 "right Rear Tone Wheel" and it says that it was a "previously set DTC"
fmc_smt
Cottonwood , Arizona
Check you right rear wheel bearing , he'll check both . Known issue .
KilluminatiDre
2015 Mustang GT PP
Will there be anything specific to look for on the bearing other than play? I checked for play and there is none. I also ordered a new ABS sensor since it was only $11. I'm not too sure how to disconnect the wire end of the old ABS sensor and can't really find anything online. I don't really see anything to press on to get the connector out.
fmc_smt
Need to get the wheel off the ground and shake the ship out of it . Doubt it is a sensor . I had a left rear fail at 20k .did notice any noise or anything caught it when I was replacing wheels .
KilluminatiDre
2015 Mustang GT PP
I have the car on jack stands right now. Weird thing about my issue is that the get the jerking with all of the systems turned on then as soon as the car shuts off advancetrac, abs, etc it drives smooth.
albert_s550
Miami
albert
2016 Ford Mustang GT PP1
Did you find what the problem was ? i'm having the exact same issue
waelaburezeq
UAE
Wael
Mustang 2015 GT
when you say jerking, do you refer to transmission jerking?
My car has thrown this on Forscn, gearbox is kind of "slipping" and car goes into "limp" mode.
KilluminatiDre
2015 Mustang GT PP
Gotcha Thanks ! I’m having the same issue . Did a pull and a couple seconds later the abs and advanced trac light came on along with the U0415 code
I have a manual. Its was more of a limp mode jerk which was caused by the abs sensor going crazy.
jonesy67
Buffalo, New York
William
V6
The DTC codes you provided suggest a communication problem between different modules in the car and a battery voltage issue.
The U0415 code appears in multiple modules and indicates an invalid data issue with the ABS control module. This could be causing the Advancetrac warning message and the service Advancetrac message you are seeing.
The U3003 code also appears in multiple modules and indicates a battery voltage issue. This could be related to the communication issues between the different modules.
https://dtcvehicles.com/
KilluminatiDre
2015 Mustang GT PP
It was an ABS sensor for me. Fixed this years ago.
Regenerate response
