Hellion car blown head gasket
TT15GT
Montz
2015 Yellow GT
Blew a head gasket the other day. While i have the heads off i am changing the springs. Any recomendations?
TT15GT
TT15GT
Montz
2015 Yellow GT
TT15GT
TT15GT
Montz
2015 Yellow GT
see my thread.http://www.mustang6g.com/forums/showthread.php?t=52488&page=6
Same thing just happened to me .
I am having the block re decked and heads checked while they are off.
I would definitely upgrade the springs and consider cams since you are there.
Yea im gettin the heads checked while they are off. Im going to keep stock cams for now. Jus want to upgrade springs. Thinking of goin with trick flow as some guys around me have used them. Just wanted to get other peoples opinions to
Chargedguard5.0
Dallas
2015 GT
Who tuned the car? If u don't want to answer could you pm me.
Mod Mustang Racing
California
www.modularmotorsportsracing.com
Worlds Fastest & Only 5 second Coyote
While the car is apart we suggest the MMR Billet head dowels, these help prevent the heads moving around on the spring style dowels supplied form the factory. These make a huge difference in the engines ability to retain a headgasket and we use them on applications over 50psi! You can find them here: http://www.modularmotorsportsracing...ge=product_info&cPath=4_30_59&products_id=952
Also, while it is apart, you would be silly not to change the following parts:
Oil Pump Gear
Crankshaft gear
secondary Chains
Chain tensioner reverse bracket
Let us know how we can help!
TT15GT
TT15GT
Montz
2015 Yellow GT
Thanxs. I have evrything except head dowels. Will order them to
olaosunt
Indiana
Updates?
Is your car back together?
TT15GT
TT15GT
Montz
2015 Yellow GT
Updates?
Not yet. Brought the heads to get checked and get valve springs put on and found out that the exhaust valve guides were worn out. Should get the heads back tuesday and will put the car back together next week
olaosunt
Indiana
Nice.
Did the heads need to redecked?
And did you get the billet dowel pins MMR was talking about ?
What springs did you end up with ?
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
trickflow 2 springs should suffice!
Teezlr
Nashville, TN
www.JakeTiesler.com
Jake
2021 Mach 1 HP - 2000 Land Cruiser - 2001 Sequoia
Oil Pump Gear
Crankshaft gear
secondary Chains
Do you guys do car labor or parts sales only?
Mod Mustang Racing
California
Parts sales and engine labor only (we do not accept vehicles at our facility). We can however refer you to a local authorized dealer.
TT15GT
TT15GT
Montz
2015 Yellow GT
Nice.
Finally got the heads back from shop. Machine shop had to take .005 off the heads. I did order the head dowels and i went with the trick flow springs.
