Heel / Toe - Accelerator pedal to low?
maddog1982
UK
Mustang GT (S550)
Does anyone else find the accelerator pedal way to low for heel and toe shenanigans? I have full access to a machine shop and thinking I will make a plate that sits under the pedal assembly to space it out. Wondered if anyone else has done it?
hinch
uk
Sideways
you can buy a "billet" plate thats like $200 in the states, or you can do what alot of the yanks did and go home depot and buy some ptfe/silicone hard plasticy stuff type spacers bring it up about an inch, or you can be a cheap ass like me and just stack a load of spare washers under it. depends if it'd cost you much to make a little plate / set of spacers to fit under it.
Burkey
Australia
I was in the same boat at first. A little practice and it works nicely. You just need to get used to the idea that you’ll have very little of your foot on the stop pedal. Shoe width helps a LOT.
The bigger issue is that if you lift the pedal, the heights won’t work if you’re braking hard. Eg. Track use or similar braking aggression.
LewisL
Bristol
Lewis
Ford Mustang GT Shadow Edition S550
I got big ass feet so it's doable but would be easier if it was higher if you make something and it works deffo be interested in it
