VictorH
- Mar 4, 2021
- South Carolina
- Victor
- 2021 Mach 1
I'm trying to track down some rear end noise. It's worse once the car is all warmed up and has gone 20+ miles, more noticeable at low speeds like 20mph and less and sounds like drive-line, intermittent, speed sensitive clacking.
I just checked ALL the bolts in my rear-end. Nothing is loose including the axle nuts. The only thing I notice is that both half shafts (both are stock) have a little bit of vertical play, (grab the shaft and try to move top-to-bottom, I'm NOT talking about back and forth axial play). Almost enough that I can make it "clunk" just a bit by hand.
Is that normal? The question is, should there be no play at all, like a wheel bearing, or is a "little" play normal?
Car is mostly street, no drag-race, no launches, but has seen some track use (by some I mean about 6-7 track events since new, which is just now about a year).
