H-Pipe Install Gone Wrong
chandlermaxwell
Statesboro, GA
2017 Mustang GT Premium Fastback
I made a rookie mistake when installing my new h-pipe. I measured the H-Pipe against the stock resonator and then read the instructions and cut off too much so there was about a 2 inch gap from mid pipe to the tail pipe section. :headbonk::frusty::doh: I had to get on the road pretty quick so I basically did a redneck fix and just clamped two ends of a cheap resonator tube from Autozone into the two sides to get by but it sounds like it has a massive exhaust leak. What's the best way to get this fixed? Have an exhaust shop weld in an extension and then weld in the H-Pipe in the rear?
Mustang_Lou
Toronto, Canada
2020 Mustang Bullitt
chandlermaxwell
Statesboro, GA
I had thought about just buying an x pipe and seeing if I like the sound better. Though I may like the H-Pipe with the Roush Axle Back if the sound improves IF there is a leak. If there isn't a leak and it just sounds the way it sounds I will have to figure out something else to do with my exhaust. The car sounds almost like a Harley at low RPMs and then doesn't gain that Roush sound back until you get up to 4000 rpm or better.
use bubble gum, MacGyver would ... :)
Anthony 05 GT
Northern Harford County Maryland
2005 Mustang GT, 2015 Mustang GT Premium
An exhaust shop can take a section of pipe and expand it slightly so it overlaps then weld it.
control4userguy
Los Angeles
2018 GT Premium
Just install some electric cut-outs to take up the space :)
ScottsGT
Lake Wateree, SC
Scott
2015 GT, DIB
Check Craigs List for a cheap take off and start over? Remember, measure twice, cut once.
Edit: I know where there's a free one in Columbia.
GreenS550
Houghton, MI 49931 Oakland, MI 48363
Bob
2019 Mustang GT Premium 2020 Explorer Limited
I would get on ebay or Jegs and check out some of the stainless steel short pipe clamps. I've used them before and they were very good.
M151A2
Skinny old dude
Central Florida
Emmett
2016 GT
Drive down to Tampa and you can have my entire exhaust system from the cats back.
Hell, I think I have 2 of them here in the hangar.
