Gurney flap - check your spoiler!
Tony_the_Brit
Indiana
Tony
19 GT350
First of all, I think I may have discovered 2 more reasons why Ford doesn't recommend using the Gurney flap on the road. (The one normally quoted is fuel consumption.)
On the track it is exposed to high speeds for a relatively short time but in thousands of miles of highway driving the pummeling it sustains will push down on and vibrate the trunk lid and spoiler endlessly. After about 500 miles with the Gurney flap in place (driving to and from tracks) I noticed that my spoiler was slightly loose on the trunk.
I tightened up the 4 nuts that hold the spoiler to the trunk. 2 are under the big rubber plugs at each end and the other 2 require removal of the trunk trim piece. Tip - to remove the plastic cover over the lock, look underneath. You will see that you have to push a small screwdriver or similar between the plastic cover and the lock to free it. 10 minute job and no more looseness.
The 3rd reason is that the flap restricts rear visibility - less of an issue for camera-equipped cars when reversing.
sox3
Newark, Delaware
George
2019 GT 350 Performance Blue
Thanks for the info.
I checked mine today. No issues, not loose. 6000 miles with Gurney flap installed.
Nardly
Virginia
Bernard
21 Mach 1 Twister Orange M2425 Chassis
Use a dab of blue loctite and that'll solve your problem. Used a lot on my Wide Glide.
Bitten in '69
Round Hill, VA
Fred
19 GT350, 22 Ecoboost HPP, 90 GT, 82 GT
I wouldn't use loctite on those. Even just blue might cause the threaded inserts to break loose and turn. YMMV
SchnellGT350
Danville, CA
Rob
2020 GT350
Just picked up my 350 LDR week. Have noticed some flex in the wing (Swing) but doesn’t seem loose - may pull the plugs out this weekend to give it a little snug but is it normal to feel like the wing flexes if you put some pressure on it?
Tony_the_Brit
Tony_the_Brit
Indiana
Tony
19 GT350
Yes. It will flex but the base shouldn't move in relation to the trunk lid.
