GT350R Replica Wing
firestarter2
NYC
RR G350 Track
Which is the best GT350R Replica Wing still available. The only ones I can find are the Anderson Composite and random Ebay $100 ones.
Edit It should read GT350R I can not change it for some reason
Bulldogs22
Atlanta
2019 Shelby GT350
Wait for the new 19 normal 350 swing to become available in person I prefer it over the 350r wing as you know people wont have the same wing off ebay for $100 like the R.
Furiousone
Central IL
2018 Ford Shelby GT350
Speedkore. I recently contacted them and they responded quickly, but I decided to just buy an R so I haven't made the purchase. Its going to run you around $2200.
firestarter2
firestarter2
NYC
RR G350 Track
Thanks! 2200 is a bit more then Im willing to spend so that helps narrow it down.
Furiousone
Central IL
Yes- its quite a bit more than say the Anderson Composites version, but it is made using R molds and comes in painted black(like factory), matte carbon fiber or gloss carbon fiber. They will also provide you an installation template that is much more robust than the AC paper template. Note you will need to provide a deposit for the template kit, then you receive that back when you return it. $75 I believe. I think that the difference in accuracy and quality warrants the extra $$$, so to me I'd rather wait till I could pull the trigger on the Speedkore. Good luck in your decision.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
Whatever you do, please don't buy a shit carbon fiber wing. They crack. CF is a complex material to work with and is priced accordingly.
NoXiDe
GA
GT350
I'm not sure when AC gave you paper templates but they now use plastic punch down templates. All you have to do is grab the wing, put the plastic punch down underneath the wing and set it on the trunk. Use painters tape and tape the template down. Remove the wing when the mount is at a desired position. Punch it down and drill blah blah blah... here's a video.
Take a look at @xNoXiDe for 350R AC pictures.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
Mach4.6
LBC
Paul
17' GT350R, 11' GT500, 07' GT500, 04' Mach 1
Anderson is coming with a new GT350R rear spoiler & it's molded off a OEM piece, I loaned them my Dog Bones to reproduce also.
I will be picking up the new GT350R Dry Carbon hood next week, this is a brand new tooling with center and side vents molded in,
I've seen the pictures and it's awesome!! Stay Tuned!!
Paul
