Gt350 x pipe on a 5.0
Grayghostcoyote
Williamstown.NJ
2021 Mustang GT 10r80
Mbrp says their 3 inch x pipe for the gt350 won’t work on a 5.0 …why? Dimensions and bends look the same… I can only think of is where it connects to the OEM header down pipes. I have 3 inch mbrp race cat back and want to change out the h pipe for an x pipe. No options out there other then a 700$ corsa double x pipe or a gt350 x pipe
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
I believe you are correct, you’d need a reducer to connect the 3” X pipe to the cat pipes. If I recall correctly the GT350 connection is bigger than the GT.
Grayghostcoyote
Grayghostcoyote
Williamstown.NJ
after some further research ... the GT 350 OEM connection is 2.75 and the 5.0 is 2.25....so unless I got another adapter it wont fit
