GT350 Steering wheel
pinero61
Houma, La
'15 Ruby Red Base GT PP
hi
anyone on here that can order me a gt350 steering wheel and ship to the uk and I will pay them by paypal or transfer
we just are not getting what u guys get in the us
We're having trouble getting them as well. Your best bet would be grabbing one off of eBay. You'll pay a bit more, but you fair a much better chance of getting one. Also, you'll be better protected as the buyer going through them.
LevittownFordParts
Worldwide
Benny & Mitch
S550's!
hi
We ship internationally but do not expect any new orders to get filled until at least January
-Benny
dconfer
PA
2019 Mustang GT
If I could install it I would order one. I really like them, but not me doing the install.
Dirtyblueshirt
Award Winning Taste™
Anaheim, CA
Aaron
2022 Ford Ranger Lariat Tremor
It's a lot simpler than it sounds.
You need:
A long allen wrench or some other long thin tool to unhook the airbag clips
small flat head to disengage the connector locking clips on the airbag
24mm socket
Torque wrench
T20 Torx for the buttons on the wheel
just make sure you unhook the battery, and you can have it off and back on in less than 45 minutes for a novice.
greg hazlett
Chesapeake, VA
2017 Fusion Sport
You need:
24mm socket
Torque wrench
Little more involved than that if you are an automatic but that basically sums it up; I did a write up on it if you are interested in seeing it.
greg hazlett
Chesapeake, VA
2017 Fusion Sport
Received the GT350 steering wheel ans installed it last night; I read the different threads on various forums and while they were a help they were not as complete as I would have liked to have seen it..so here goes!
Move drivers seat back all the way FIRST!
Disconnect negative battery cable with a 10mm wrench
Use a 7mm socket/T20 tork bit to remove the bolts on the underneath of the trim panel of the steering wheel.
Use a pick or something similar to pry the upper/lower trim pieces from the steering wheel
Locate the small access holes behind the paddle shifters and use a small allen wrench to place in the hole and press in to release the air bag on both sides.
Unclip the orange clips (2) and pull up to remove the plug ins; also remove the sensor that is plugged in, remove airbag and place out of way.
You can now see the 24mm steering wheel bolt, there is also a connector at the top that needs unpugged. Remove bolt and wiggle steering wheel out.
I brought the old steering wheel inside and places the GT350/stock one next to each other and noticed since the GT350 is a manual there is no place for the paddles shifters to fit so you have remove the stock plastic paddle shifter part and transfer it over to the GT350 steering wheel; use the T20 tork bit for all the screws and transfer the controls over to the GT350 wheel.
Re-install is the reverse but ensure your wheels stay pointed straight ahead when installing the steering wheel, somehow I moved mine and thought I was done...sigh...had to take the wheel back off and align the wheel to the tires to ensure they were correct.
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
Well there was a pleasant surprise from Levittown today:
Thank you for your order. Your parts are on the way!
Santa Clause is real, and his name is Benny [MENTION=9199]LevittownFordSuperCenter[/MENTION]. :)
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
+1
Mine is also on the way, thanks Benny, my car is also on the way as well. Woop woop! :D
Need 4 Steed
Houston, TX
2015 Mustang GT PP
Just got my "shipped" email [emoji16]
MtnBiker
San Antonio, TX
2015 Mustang GT PP
Just saw my "shipped" status on the Levittown site. Stoked! Will make it before Christmas.
Need 4 Steed
Houston, TX
2015 Mustang GT PP
Seams like Levittown is the only supplier getting shipments. So glad I went with them.
Thanks Benny[MENTION=9199]LevittownFordSuperCenter[/MENTION]
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
Near the end of October.
