superman07
- Jan 12, 2016
- columbus ohio
- 2016 gt350
how long is a shifter install take?
The wiring harness for the cooler is clipped to the IRS cradle. To remove the cradle it's very easy.Back to the axle diameter question. The 2004-2006 GTO's had a huge wheel hop problem. Aftermarket axle suppliers began making anti hop axles that had one significantly larger than the other one. It was explained that a harmonic vibration contributed to the hop and the different axles helped with this. The makers said it didn't matter which side had the larger axle. On a side note, can you see where the wiring for the rear cooler goes? I still hope there is a harness or empty plug somewhere us tech pack cars can use to wire the rear cooler.
My time will be less because I have no exhaust or driveshaft in my way.how long is a shifter install take?
I was hoping to have it done by now, I powder coated almost everything I needed but I ran out of red so I have to only finish the springs and sway bars. If I don't get to buried in work at my business I hope to start reassembling by late this week or next weekend. I'll keep you posted.When are you estimating all your work will be wrapped up and completed? Got my MGW shifter in as well, can't wait to install it!
With the stiffer bushings you have no movement. When something moves such as a violent wheel hop, that's when things break. When the suspension is worked such as in hard cornering and braking, that puts more weight and stress on the suspension and When rubber bushings are used, they are great at reducing or eliminating noise and vibration but suck at everything else.Will the stiffer bushing make it more likely something will break? Also the IRS bushings are they pressed in?
A friend of mine tracks his GT a lot and he's already torn 2 IRS cradle bushings in his 2015 GT.
I will be doing his next.
The stock IRS cradle bushings are pressed in. A lot of guys like to cut them out with a sawsall and that works, but the way I always done it is heat up the center steel sleeve with a torch just to get them slightly hot and the center will fall right out. Then use a air chisel on the outer shell and they pop right out in seconds. Both ways give the same results. The new bushings are more of a snug to tight fit and can be either pressed in with a C-clamp, a nut and bolt through the hole and tighten them until they are seated or tapped in with a dead blow hammer. I use a C-clamp with a piece of hard rubber on both ends of the clamp to protect from scratching the bushing finish and tighten them until they are seated.
If you want to replace the rubber bushing with solid ones, yes. But you could use "lock outs"Is that something you have to drop the IRS to do?
Fortunately the GT350's use a higher durameter rubber which will hold up better and longer vs's the GT's albeit they are still rubber.With the stiffer bushings you have no movement. When something moves such as a violent wheel hop, that's when things break. When the suspension is worked such as in hard cornering and braking, that puts more weight and stress on the suspension and When rubber bushings are used, they are great at reducing or eliminating noise and vibration but suck at everything else.
Lol. I used what I had left over from my HVAC unit in my shop. I installed a furnace and AC unit in my shops attic space and made the supports to mount it. I used what I had left over. I was going to make it out of tubing but figured if I made it from versabar I could take it apart or if someone from the forum wanted to make or rent it they could and I could disassemble it to ship it easy.VOODOO your 1-5/8 metal framing cradle is cool.
That is the product my company manufactures.
Versabar Strut Systems.
Maybe I can sell GT350 rear end cradles.
LOL
