GT 2019 : High beam issue
Dizzy33
France, Gironde
Lionel
Mustang Fastback GT 2019
Hello,
first of all I am french so my english may not be good, I hope you will understand what I am trying to say ...
I own a 2019 GT. I have an issue with high beam : when high beams are set to automatic, high beams work. But when I try to manually activate the high beams, it does not work, even if I disable the automatic mode for high beams.
Did anyone meet this issue ?
What could be my problem (except the high beams button itself) ?
Thanks !
Snakebyte
West Central Florida
Nathan
2019 Mustang GT Convertible
Not sure about the Euro specs, so I don't know your high beam - fog/driving light requirements.
In the US, if you have driving/fog lights on, usually you cannot have high beams illuminated concurrently. So if your specs are like the US and you have fog/driving lights, can you manually turn them off and then try the high beams?
Nightmonkey
Germany
Jens
2020 Bullitt
Can you upload a video?
Could be incorrect operation, the handling takes some getting used to.
Dizzy33
France, Gironde
Lionel
Thanks for your reply. I tried all possible combinations of lights turned on or off, but I cannot activate high beams manually.
Dizzy33
France, Gironde
Lionel
as it looks like a bug, I wonder if I will not try to disconnect / reconnect the battery ...
Nightmonkey
Germany
Jens
2020 Bullitt
What happens, when you deactivate auto high beam in the HMI settings?
Does flashing the high beam work?
Dizzy33
France, Gironde
Lionel
No flashing the high beam does not work, whatever if auto high beam is activated or not.
luca1290
Italy
Luca
Mustang GT, MB A250 4Matic W177, Mazda MX-5 ND, Ford S-Max 2nd series, Lancia Y
Do you have Forscan? In this way you can see if the SCCM is sending the high beam request on the bus.
Dizzy33
France, Gironde
Lionel
Sorry but I do not know what is Forscan ... I guess it's a tool to connect to the car computer ?
Nightmonkey
Germany
Jens
2020 Bullitt
https://forscan.org/
Worth the money, i have the Android version with me in the car (phone + wifi dongle).
If you don't have a capable OBD-Tool and don't want to buy one, go to a Ford dealer.
It is quite possible that only the high beam switch is defective.
Is your Mustang EU spec, or is it a US spec that came to you as a salvage title via Lithuania? These Frankenstangs sometimes have gizmos...
Dizzy33
France, Gironde
Lionel
As our gen 6 are full of electronic things, I wondered if that issue with the high beam in manual use could be due to just a bug of an electronic board managing the high beams. So I disconnected the battery, waited for 1 minute, then reconnected it. And guess what, now high beam in manuel mode does work again !
So this experience can be interesting for you, if you face the same issue.
