GROUND CONTROL Conversion Kit REVIEW
BlownStang15
Australia
2016 Mustang Shadow Black
I wonder how much the full coil over kit without camber plates would cost. Perhaps Ground Control can chime in.
I second that motion :)
GCSystems
Shingle Springs, CA
'05 Mustang GT
I'm not 100% sure our coil over conversion kit will work with the Steeda camber plates. Our camber plates are designed to fit our custom valved Koni struts(different threaded portion) as well as a 2.5" inner diameter spring.
With the price being a "complete kit" price, it may be easiest to sell your current camber plates and apply the money towards the complete system.
Thanks!
Trevor
Niz55
Us
17 GT350
Just got the front installed and waiting to put on the rear. One thing that wasn't mentioned was that you need to press out the bearing from the factory strut mount and onto the gc mount. Nothing hard but you will drop punch of ball bearings.
Trevor,
Is the sleeve made out of aluminum? Seems really weak and thin. I can easily flex it with my hand. Is this going to be an issue?
I just hope this kit doesn't make any clunking/clanking noise.
Btw, these are 400lbs springs that are 6". I hope I get the same height as the Sportlines if not I be switching these out to 475lbs 5" like Trevor mentioned.
West TX GT
Ian
2018 Royal Crimson GT
I cant wait to hear your thoughts about them since you have tried a few different setups.
Niz55
Us
17 GT350
Don't mind the first picture. That was only for fitment purpose. The bearing is installed upside down. The correct way is the green part should be on top.
Bbarfoot14
Bbarfoot14
RI
2015 Mustang GT PP
Trevor,
You won't be able to run a 5 inch spring as the spring will bind. You can go with that rate on a 5.5 and get sportline ish height if my memory serves me.
