Grinding/creaking noise on hard bumps
rebelyell22
Tupelo, MS
2021 Twister Orange Mustang GT Premium
I had Steeda Progressives installed a month or 2 ago and I’ve had a creak/grind noise on my front driver corner on hard bumps. I don’t see any rubbing anywhere…. Any ideas?
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Usually noise from the front is from the sway bar end links not being torqued correctly. I learned this the hard way, hitting them with an impact is not good enough.
Call Steeda they will help you.
rebelyell22
rebelyell22
Tupelo, MS
Still having this issue on big dips in the road and bumps. Only on the driver side…. It almost sounds like metal on metal. I’ve looked all in the wheel wells and I can’t see where anything has rubbed. Should I still check the swaybar?
