Go/No-Go Gauge?
NGOT8R
Adrian
2019 Bullitt
Let me know if you guys would like any other measurements before I air them back up. I’ll give it 10 minutes. If I don’t get any other requests within that window, I’m airing them back up to where I need them.
rxryanm
rxryanm
KY
2019 GTP PP1
No sir, I appreciate it and you greatly! Looks like it should fly to me.
Coyote Chase
Don
2010/2018 Mustang
If you go by the wear marks, my ""275" M/T drag radial tires measure 10.5 inches. They also fit within my wheel wells, which is another regulation, you may find in other association's rule books. With 3.55 gears, you should be fine running 28+/- tall tires.
rxryanm
rxryanm
KY
2019 GTP PP1
the event staff would have the so called '' go/no go gauge'' ... that tire should be fine. my 20 gt looks the same as the above one. the treadwidth is only about 10.5inches . typically with it being a 17in wheel vs a typical 15in wheel they let it slide. (less sidewall advantage). Your best bet is to reach out to the Drag Week Event staff... I am also shocked you got in. Typically drag week is full within minutes.
Update from the staff for those of you who are curious - the class I'm going to be moving into has 0 tire requirements other than drag tires on the track. So I appreciate all the help, but I definitely jumped the gun. That's on par for me tho.
So my eyes are open for a good deal on likely ET Street R 305/45r17 and some Sportsman S/R 28x6R17.
Proshop
Billy
2021 Ford Mustang GT
If you needed 19’s I could get you a good deal a slightly used pair.
