ghost steering issue
xshatterstar
philippines
Oliver Comia
Mustang GT Premium 2023
So I was cruising around and suddenly my steering became stiff like im driving in the mud. I scanned the car and it shows Code u0415. Dealer and a shop i brought the car into can't figure out for the love of god why my steering is like that. After a while A/C codes also came recirculation damper motor mechanical fault and short to ground i think from the actuator. I brought it to the dealer again to fix the A/C issue and after they fixed it, for some reason code u0415 is gone but the A/C codes remained as well as the stiff steering. I dont know what else to do. Please help
xshatterstar
philippines
Oliver Comia
PS. I have a new battery and also had the dealer change my wheel speed sensors. The shop I brought it into also cleaned everything and checked wirings as well as the wheel hub but they said there's nothing wrong.
horsepower addiction
Arizona
Nate
s550
I had a similar issue once. I was driving on a mountain road gettin it when all of a sudden my steering felt like it locked up. It didn’t though, it just got really hard to turn. The power steering is electric and the power wire somehow wigged loose enough that it lost connection. The electric power steering is connected to the abs module. You should look at the connections to the power rack and pinion steering, check the wires for damage, check the power steering fuse, the steering angle sensor.
xshatterstar
philippines
Oliver Comia
I already had the dealer check as well as a reputable shop all the wirings including the wheel hubs and they both found no damage thats why im stuck with this problem
Arizona
Nate
s550
The they checked the EPS? Did they say that it has power to it? Did they check the steering angle sensor? What did they say? Is there a signal?
Arizona
Nate
s550
Did you check to see if you car is part of the recall for the EPS module? Did they check the torque sensor.
Arizona
Nate
s550
Do you have a steering assist fault message or drive mode unavailable message? If there is power and no messages did they listen to hear if it’s trying to assist? Did they check the belt?
xshatterstar
philippines
Oliver Comia
I dont have any warnings lights and they also checked the steering rack but im not sure about the eps system. I did check steering torque and angle, i have a 1.6 degree offset alignment
Arizona
Nate
s550
If everything checked out good it has power and it sends a signal to assist when you turn the wheel. The next thing I would do is have someone turn the steering wheel while I listen and feel the rack to insure the motor inside is working. If you can feel and or hear the motor working then I would check the power steering belt. Before you start say that there isn’t a power steering belt. Yes there is. It’s inside the rack and sometimes they break or the cogs break
