Gen 2 timing, crank stops w/ resistance
King138
Maumee, Ohio
Andrew
2016 Performance Pack GT
Almost embarrassed to ask. In the middle of timing my new motor with Gen 2 timing sequence. 1st time I did it had zero issues but second guessed what I did and tore apart. Twice now, I’ve finished the driver side per the ford manual. When it comes time to rotate the crank one full revolution to 5 ‘o’clock then to 12 o’clock. It stops at 5 with alot of resitance and doesn’t want to move anymore. I’m using the wrench crankshaft positioning tool to rotate the crank. What am I missing?
mepawn
Ohio
Joseph
From what I remember you do not complete a full revolution and then to 12 o'clock position.
You move from the 5 o'clock to the 12o'clock position rotating the crank clockwise.
Ive used this video for reference. Gen 2 Mustang 15-17 Coyote Oil Pump Gear Install and timing procedure *watch entire video* - YouTube
Also you can pull the service manuals as they also explain it.
