Gauge cluster shutting off while driving
Jtb986
Ohio
2017 Ford Mustang gt350, 2009 Aston Martin db9
Hey all, let me know if anyone has seen this before, I have a 2017 gt350 and if I trigger traction control the entire gauge cluster completely shuts off for about 3 seconds, then turns back on. Everything is fine from there, but there is a traction control light on for a couple seconds which also goes out, leaving everything as it was, no codes, warnings, or anything. The same thing happens if TC is turned off and I break the rear tires loose without triggering TC.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
I had this issue once on track when my by battery got loose and the connection was shorting. I’d check for a bad connection or ground.
Jtb986
Ohio
Checked the connection, it was tight but for the hell of it, took out the multimeter and read 12v exactly, had a couple weak starts in the last couple of months, might be new battery time. Weak battery causing TC problems?
