New York Fully Built TT 2018 Mustang - Th400, Twin 72's, Sleeved, Cage, etc
Limitless100
New York
Looking
Turn-key car with a ridiculous amount of money put into it. I have a folder of receipts for the car that will go with the sale, I have many other pictures/videos I can send to anyone interested. Please message me directly if you're seriously interested.
4800 chassis miles and ~1300 or less on most of the parts.
*Title in hand*
Built and tuned by:
R&S Racing / Automotive specialists in PA
L&M Racing engines
Rob Shoemaker (PBD) Tuning
Engine:
  • L&M Built Engine (Built for 30+PSI & ~1700+whp)
  • Gen 3 Block
  • Extra Thick Ductile Iron Flanged Sleeves
  • 11:1 Custom Forged Diamond Pistons
  • Manley Pro I-Beam Billet Rods
  • Forged 5.0L Steel Crankshaft
  • Total Seal Rings
  • King Bearings
  • ARP Studs
  • Cometic Head Gaskets
  • ATI Balancer
  • O-Ringed
  • Billet Oil Pump Gears
  • Slawko Ported Heads
  • L&M Camshafts
  • Ferrea Intake & Exhaust Valves
  • PAC Valve Springs
  • L&M Titanium Retainers
  • ARP Phaser Bolts
Twin Turbo System:
  • Aldo Welds Top Mount Twin Turbo Kit
  • Forced Inductions 72/75 Dual Ball Bearing Billet Wheel Turbos
  • PNR 2000hp Air-to-Water Intercooler w/ EMP Pump & Trunk Tank (hidden under trunk carpet, trunk 100% usable)
  • AMS 2000 Boost Controller, C02 Regulated, All Options
  • Turbosmart Oil Pressure Regulator
Fuel System:
  • Fore Innovations In-Tank Triple Pump Fuel System
  • Fore Innovations Fuel Pressure Regulators
  • Injector Dynamics ID1700 Fuel Injectors
  • Pump E85/One Ethanol S/R
Exhaust:
  • Corsa Exhaust w/ Electronic Dumps (can go from calm to race car)
Electronics:
  • N2MB WOT Box
  • Davis Technologies Bump Box
  • JPC Line Lock
  • nGauge Tuned by Rob Shoemaker from Palm Beach Dyno
Drivetrain:
  • M&M TH400 Transmission (1.77/1.34/1.0) w/ External Dump, Safe Neutral, Trans Brake (Fresh Rebuild 2022)
  • Transmission is Totally Overbuilt, $15K Transmission Built for 2500hp
  • Pro Torque Converter
  • M&M Shifter
  • Custom Spec’d PST Driveshaft
  • Torsen Differential w/ 3.73 Gear (Fresh Rebuild w/ New Bearings & Ring/Pinion Late 2022)
  • G-Force Outlaw Axles w/ Full ARP Upgrade
Suspension:
  • KellTrac XTR Crusader Viking Dual Adjustable Coilover Kit
  • KellTrac S550 Shock Bearing Upgrade Kit
  • KellTrac Derlin Adjustable Camber Links
  • BMR Adjustable Toe Links
  • BMR Rear Drag Springs
  • BMR Caster/Camber Plates
  • JPC Crossmember & Driveshaft Loop
Wheels/Tires & Brakes:
  • 17x4.5 Weld Alumastar 1.0 Powder Coated Black
  • 17x10 Weld S79 HD Beadlock Powder Coated Satin Black
  • 28x6x17 Mickey Thompson Sportsman S/R
  • 315/50/17 Mickey Thompson ET Street R (tires only have under 400 miles on them, 0 burnouts)
  • Baer Drag Brakes All Around
  • Rotors & Brake Pads Replaced in Last ~500 Miles
Interior:
  • 10-Point NHRA 8.50 Certified Cage w/ Swing Outs, High Quality Tucked Cage Install, Window Net
  • Motion Raceworks Chute Handle
  • Kirkey Seats
  • Rear Seat Delete
  • GT350 Steering Wheel w/ Transbrake & Bump Buttons Integrated
Exterior:
  • Motion Raceworks Chute Mount
  • Parachute
  • Carbon Fiber Rear Spoiler
  • Blacked Out Emblems/Accenting
*Track info* The car only made it to the track for a few runs by original owner. On Wastegate, soft rollout, it went high 9's at 160. It broke driveshaft on mid boost run (~15). Current custom driveshaft was replacement.
Price: $70,000
Joshinator99
Massachusetts
Josh
2022 Mustang GT Premium, 2017 Camaro 2SS
Killer build and beautifully done! GLWS
Limitless100
Limitless100
New York
Looking
Why you got it for sale is what I want to know
That's easy, don't want a drag car anymore. Looking to move into something that is street and roll focused. I'll never bring this car to a 1/4 or 1/8 which is what is was built to excel at. For the way I use it, it's just a total waste for me to own it. I don't want to start ripping it apart and changing things either, would rather just sell to someone who wants a street/strip car :cool:
Limitless100
Limitless100
New York
Looking
Power/ boost right now? Beauty!
Thanks!
It has 5 settings on the AMS then wastegate. I use Wastegate 95% of the time because it's used on the street and it makes 900 wheel Lol. Wastegate is like 8 psi then setting 5 is only 17 psi and it makes around 1300 there
