Fuel Systems!
JakeLethal
Wellington, FL
Jake
2022 F-150 RCSB 5.0
Are you needing to go E85 on your boosted setup but need more fuel? Well here's the answer! The Lethal Performance 2018+ return style fuel system was designed for those looking to make big power as well as have the option to run different fuel types. Only a couple more days to get this amazing system for 10% off!
Shoot us a message or give us a call at 1.561.753.8105 and we'll be more than happy to assist you in getting this configured for your horsepower goals!
https://www.lethalperformance.com/info/black-friday-2020
Tom@Lethal
Utah
Thomas
2020 Shelby GT500
Full fuel systems right here! ☠🔪
https://www.lethalperformance.com/l...elby-gt500-5-2l-return-style-fuel-system.html
Snoopy49
California
Earl
2013 GT500 - SOLD and 2020 GT500 - SOLD
Tom@Lethal
Utah
Thomas
2020 Shelby GT500
Tom,
Can you give a breakdown showing what the horsepower limit is for each option?
Say your going for 900 hp on E85, what combination would be the safest?
So our system include triple pump fuel hats that can either be ran with 2 pumps and upgraded later or 3 right out of the gate.
Our harnesses are triple as well and like the pumps can either be ran with 2 pumps and upgraded to 3 later or right from the beginning.
as for pumps, you’ll see the most common setup is going to be 2/3x Walbro 465lb pumps. We also have options up to 2/3x 535lb walbro pumps but most common we’ve seen withoir kits, to include s197/s550s, are the 465lb pumps.
The next potion is just as important as your pump selection with it being injectors and a minimum of 1000cc FIC or 1050x IDs. This paired with the walbro 465 pumps will be good for around 900. Now, if you’re going to go passed that then do 3x pumps and either 1440 FIC/1300 ID injectors.
kits all come with pre assembled PTFE hoses and fuel rails as well.
Snoopy49
California
Earl
Tom@Lethal
What max hp will the stock pumps support, 91 Oct & E85?
Tom@Lethal
Utah
Thomas
2020 Shelby GT500
Tom@Lethal
Based of info we’ve seen through PBD/Lund at around 750 u need at least id1050s on E85, and above 900 you will want the rails. That power above is on stock pumps with a BAP as well.
