Fuel Rail Removal
Bahndvr
Roushcharged
Germany
'16 Roush Warrior Mustang
Anyone removed the fuel rail (after blower is mounted) to change injectors?
It looks easy but the cross-over is in the back?
Bahndvr
Bahndvr
Roushcharged
Germany
No one has upgraded fuel injectors after originally installing the blower?
twold
u.k
66 mustang fastback
I had my whipple stage 1 injectors changed for stage 2 and they had to lift the whipple.
EDIT: Just noticed you have Roush so ignore.
Obsol3te
Hope Mills, NC
'15 GT PP
I've made the swap and I have a rear mount inlet blower.
I was doing some other shit too, so there were other things that had to come out so I had to remove the blower anyways.
Bahndvr
Bahndvr
Roushcharged
Germany
It's still a rear inlet blower
I hope I only need to remove the blower horn and throttle body
Foxracing19931
Pittsburgh pa
2015 mustang gt premium
Unhook intake..unbolt blower and take off fuel rail wasn't that hard :p
Foxracing19931
Pittsburgh pa
Oh yeah and release fuel pressure of course
Draklia
Dry Land
2017 GT
I see this on the Procharger install instructions but they don't say exactly how to do it ... likely on youtube somewhere but care to say how it's done?
Under the rear seat, unplug the fuel pump connection. Then start the car till it stalls and then crank it a little bit more to suck all the pressure out, maybe like one or two seconds. That's it. Gas will still come out when you disconnect the rail, so have a rag handy. Also be careful with the rail as it will still be full of gas. When you tip it, gas will pour out of it.
jabrax
Montgomery County PA
Jeff
2015 ruby red PP GT
I made a mess the first time with gas spillage. Second, was prepared moving slower and placing towels to catch the fuel.
I didn't disconnect the fuel pump since my car was sitting overnight. If your car has been sitting for hours, is depressurizes on its own.
Mootang
Sacto, Caliunicornia
Henry
2017 Mustang GT
Really? If my car has been sitting for weeks, I don't need to release the fuel pressure?
jabrax
Jeff
2015 ruby red PP GT
Mootang
Henry
2017 Mustang GT
Bahndvr
Bahndvr
Roushcharged
Germany
And when I push in the clutch it primes?
Why do I remove #49 fuse?
Mustang_Lou
Toronto, Canada
2020 Mustang Bullitt
I was thinking pulling the fuse is easier than popping the back seat (not that that is difficult).
